Question about Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000
I have a problem with my camera.  It's a Maxxum 7000i.  It suddenly stopped taking pictures and where the film advance is normally displayed the word "help" is flashing.  This has never happened before.
What should I do?
  • mikeagoura Feb 24, 2009
    Hooper Camera store couldn't figure out the same problem with my 7000i also.
  • Anonymous Mar 06, 2009
    I've got the same problem, anybody knows??
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Posted on Feb 24, 2009
When you put the film in the meter thats shows you how many exposures you have left stays on the s instead of going to one. The film is being pulled properly and is acting normal but even the sound doesnt...
I would definitely be concerned that the film is not advancing. I have a Minolta that has the same problem. I missed many a picture because I didn't pay attention to the meter showing the film advancing. I would just make sure the film is advancing by taking a couple shots with the back open before closing it.
If you are positive the film is advancing, it really doesn't matter what the meter says as long as the film is stopping after each exposure.
Finally, if the film is advancing , but the meter is not, and you want it to, you will need to see an experienced repairman to correct it.
Good luck.
Thanks for using Fixya.
Apr 27, 2011 | Minolta Maxxum 7000 35mm SLR Camera
Where ca i get a card for my minolta Maxxum 7000i ?
What do you mean by card? A memory card?.. If so, your out of luck. This is a film only camera.
Dec 05, 2010 | Minolta Maxxum 7000 35mm SLR Camera
When I install the battery in my 7000i it makes a noise the screen has two lines appear but the camera will not turn on.
I had a similar problem with my 8000i. Parts are getting scarce for these older Maxxums, but you can still get it repaired. Unless you are emotionally attached to this 7000i consider replacing it. You should be able to find another on Ebay for a decent price. You might also consider the subsequent generations which offer better AF performance. The 650xi, 700xi and 800xi are all good cameras and available on Ebay. Lighter versions like the Maxxum 70 and the XTsi are also available. The last of the film Maxxums was the single digit 7. It is generally regarded as the best of the Maxxum series, but still sells on Ebay over 150.00 typically. These subsequent models will take all your maxxum lenses and flashes. These newer models offer many other features and often less weight to carry around.
lightspiritphotography.com
Nov 12, 2009 | Minolta Maxxum 7000 35mm SLR Camera
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Manual for maxxum 700i
Try the following website link
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/index.html
Not sure what model you have as Minolta did not make a 700i, it is either a 7000i or a 700si, either way the owners manual for both these models is avaliable from this site
Nov 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta maxxum 7000 troubleshoot camera wont take pictures
There are several possible reasons, it could be the body or the lens. Check the shutter blades without film. Are they smooth and in place, (flat)? It could also be related to the film, a mis-load of the roll. The lens could have some failure, possibly try another.
Jun 14, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Monilta 7000i
ron,
send it to a camera shop,the fungus may have spread to the flex circuit under the top cover. there are no new parts for this model so finding a camera repair shop to clean it may take a few tries.
get an estimate first.
Dec 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
263 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
