Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer doesnt wanna spin
I was on my knees begging it to spin and it still doesnt spin what do I do!!!
    Scholar:
  • 148 Answers
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jul 13, 2008
My washer will not go into spin cycle my wife says she can hear the motor running but it isnt spinning
You might wanna check the belt. It might have gone out of the spinner rail or is broken.
Sep 12, 2010 | Whirlpool LSR5132PQ Top Load Washer
Cant play new guitar hero Metallica.....need help please!
Ok, heres what you do.
(with the ps2 slim, this will work, I'm not sure with the fat but here you are)
Turn it on with the disc in it.
Turn the ps2 horizontly with the front facing you.
Whenever you hear a tick (only for fat) tap it against you knee a few times until you hear it spinning.
I first figured this out when I was frustrated. The ticks should be in groups of two. I just taped it on my knee, then I heard it spinning, and now I know I didn't waste my money on GH metallica and world tour.
Jan 06, 2010 | Sony PlayStation 2 Slimline Console
Machine doesnt seem to wanna spin
Sounds like a slipping drive belt.
You need to change the belt.
Oct 08, 2009 | Fisher and Paykel WA37TG1 Top Load Stacked...
Washes but doesnt drain or spin
Unplug Washer
Shut of Water hoses to Washer and Disconnect from Washer.
Turn washer around and remove back cover.
Look inside fro the Belt it should either be Loose, or Broken. Just Replace.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | Washing Machines
UNLOCK BLACKBERRY 8100 FOR FREE PLEASE
I need unlock code for Black Berry 8120
Oct 04, 2008 | RIM BlackBerry Pearl 8100
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
