Getting a code 41 on brother fax 1800c g3
The printing was not clear , replaced all ink . but i am now getting a code 41 . can you please advive on the reason why? thank you
I WAS ADVICED BY A LOCAL REPAIR SHOP NOT TO BOTHER BECAUSE THE PRINTER WAS SHOT AND TO EXPENSIVE TO REPAIR, SO BUY A NEW ONE AND THAT K-MART HAS A GOOD DEAL ON A PRINTER FAX. FOR LESS THAN 50 BUCKS THANKS FOR YOU REPLY UNLESS YOU CAN COME UP WITH A BETTER SOLUTION
Posted on Jul 19, 2008
Machine does not work. message on display says: MACHINE ERROR 41 What is that?
Very likely your print head is faulty. You can get it replaced or try the economical solution below.
I had the same problem after replacing the print head. I removed the ink cartridge and then unclip the two metal two clips by the side that hold the print head. Then I used WD40 to spray through the ink holes until the clear liquid comes out from the print head.Then I replaced everything back and start the cleanning process, do a few test prints. It works ok now, no more Machine Error 41. Therefore, sometime the problem might just be clogged pin heads!
Jan 19, 2011 | Brother MFC-3220C Plain Paper Inkjet Fax
Machine error 41
May 15, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
Machine error 41
This is a mechanical problem with the printer head it will need to be repaired.
Try an authorized service center with the link below, sometimes its better to buy a new machine.
http://www.brother.ca/en/customer_care/service_centers.asp
Mar 27, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
I get error 41 how do i clear this problem
Sorry to say but the only way to clear out a error 41 is to have the print head replaced
cost around 150.00
Apr 20, 2009 | Brother Office Equipment & Supplies
Error 41
print head defective. cant be fixed anymore.
You need a new fax machine due to the fact that the spare part is more costly than  a new one!
Jan 27, 2008 | Brother IntelliFAX 1800C All-In-One...
Brother MFC 3220c machine error 41
I had the same problem with a Brother MFC3420C after replacing the print head with a new one the same error 41 occured 4 weeks later.
I finally fixed the problem (see photo's) and sent the parts back to Brother :-)
Don't buy Brother Inkjet technology its all ****!.
Their laser technology seems to be much more robust and reliable, have had a Brother HL-1440 since 2004 and its still running well.
http://www.flickr.com/photos/48446421@N05/sets/72157623635891898/
Jan 12, 2008 | Brother MFC-3220C Plain Paper Inkjet Fax
Fax mach 1800c brother
Although you may not use the other colours the cleaning assembly cleans all the cartridges hence the other ink gets used. To trick the machine into thinking there is ink in the cartridge, place some black tape over the top of each cartridge facing front of the machine. This fools the sensor into seeing no reflected light and reads that there is ink in the cartridges you do not use. Pleas enote that if you do this on a long term basis it is liley the head will dry out and may damage the head - use this advise to get urgent prints out.
Sep 08, 2007 | Office Equipment & Supplies
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC-3220C plane paper fax
unfortanatly error 41 means that the printer head needs to be replaced. Got this from the horses mouth. I called the internnational tele # at 1-800-284-4329 and they told me you would need to take in the machine to have this repaired. You can look in your book for a # to find a servicer or go to http://www.brother.com Good Luck
May 12, 2006 | Brother MFC-3220C Plain Paper Inkjet Fax
27 people viewed this question
k24674
jasbo
jasbo
