All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
Posted on Jan 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I buy a new gas regulator for the all pro 50-85 btu propane heater my zip is 21222
Anonymous
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Jan 12, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
111
Questions
Helped
36277
Points
217
Simple answer is use one for a grill,it will be close to same pressure
All pro SPC 150T propane heater. starts and runs great for 10 minutes and then shuts heat down and blows only cold air. let sit for time and it repeats process.
It is possible that the problem with your All Pro SPC 150T propane heater could be caused by a faulty gas regulator or pressure switch. The gas regulator controls the flow of propane while the pressure switch controls the temperature of the heater. You may need to replace the gas regulator or pressure switch in order to get your heater running again. Additionally, you could also check for any loose connections or clogs in the fuel line.
Have Big Max shop heater 75,000 btu new install won't light
If the Big Max shop heater 75,000 BTU won't light, there are several things that you can check:
  1. Make sure that the propane tank is full and properly connected to the heater. Check for any leaks in the gas line.
  2. Check the pressure regulator to ensure that it is working properly.
  3. Check the igniter to ensure that it is sparking properly. If not, clean or replace it as needed.
  4. Check the gas valve to ensure that it is opening properly when it receives the 24-volt signal. If not, replace it with a new one.
  5. Check the thermocouple to ensure that it is functioning properly. If it is not, it may be preventing the gas valve from opening.
If you have already replaced the gas valve and the problem persists, you may want to consider contacting a professional technician for further diagnosis and repair.
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
1helpful
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Can I convert a rinnai rce-229a from propane source to natural gas source
It should be. You should be able to replace the oriface and the regulator. Propane is at a higher pressure than natural gas.
1helpful
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
What type of regulator do i need to connect my propane tank to the heater?
You need a regulator rated for the heater. Your propane dealer can provide you with exactly the right regulator.
1helpful
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
1helpful
Can i convert my dyna glo 75000 btu propane
I'm sure you can, contact the manufacturer and ask if they have a natural gas jet or orfice for your model heater, these are usually very easy to replace.
Top All-Pro Heating & Cooling Experts
Paul Carew
john h
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
