Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite HE4 electric dryer
We have had this dryer for about 3 years now. it's started taking forever for the clothes to dry. Now it is smelling like something is burning. jWe have taken the back off the dryer and cleaned out anywhere lints could be backed up, but it almost smells like something may be touching the heating element? We have heat, and my husband said when it's on low, it won't smell. But now it's smelling immediately on any setting?
Any ideas?
  • 5,911 Answers
If this is a Kenmore Elite front loader, taking the back off isn't going to tell you much. The heating element is inside the dryer under the drum on the right hand side. More than likely you have an accumulation of lint on the heating element housing and its beginning to smolder. Running the dryer on low will not change the fact that you have lint in close proximity to a glowing element. It will still burn. Here is a link you can look at that gives you some advice on dryers:
http://www.fixya.com/support/r385301-thorough_dryer_advice
You will need to unplug the dryer and remove the lower panel under the door to gain access to the heating circuits. If you have lint backing up into the dryer, you need to investigate why. If its been a while since you've inspected your dryer ventilation ducting, it would probably be a good idea to do so. Everything is in the link I provided for you. I hope this helps.
PS Conitued running of a dryer in this condition can cause the heating circuits to overheat and fail and/or cause a fire.
Posted on Jul 13, 2008
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
The heating element may have failed. Also, the vent may be clogged.
Aug 15, 2016 | Kenmore Elite HE4 Electric Dryer
My dryer will get hot, but clothes take forever to dry.
make sure the hose is not stopped up or pinched closed. Clean lint filter.
Mar 28, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite dryer. It is not drying the clothes properly. It takes a lot longer to dry the clothes. One time it dries fast the next time it takes forever. Any ideas??
it sounds like your dryer stat real name t.o.c. you will need a engerneer to do this the job should cost no more then £40 pound ring a round for a call out the cheapperst is not all ways the best ok so make sure you ring 4 to 5 guys just tell them the problem and they should say the same if they dont get back to me and i will try for you see if i can get some one to help you in your area ok
Feb 03, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite HE4 electric dryer is making a screeching/high pitched noise. It would dry the clothes, but I can't stand the noise. Before the noise started the dryer would occassionally not start if...
Hi- The bearing(s) might be worn or the drum wheels sticking but if it is not starting sometimes you most likely have a motor issue. You'll need someone to come out and take a look at it.
Sep 24, 2010 | Kenmore Elite HE4 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite HE 4 IS NOT DRYING AND GIVING BURING SMELL
ensure the lint screen is clean, check your discharge vent hose for blockage or kinks. You may need to move the dryer out from the wall to thoroughly inspect the vent hose. while the vent hose is removed from the dryer, start the dryer momentarily to ensure the is sufficient air flow exiting the unit.
Feb 08, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
The clothes dried on high or medium heat come out smelling like heated metal
hi .thanks for the question .yes i would check all venting from dryer to the outside . clogged venting, or dryer too close to the wall could cause this problem . thanks the appliance doc
Sep 30, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
337 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
