Question about Hoover Washing Machines
Water leak under machine not the hot cold water lines
    Scholar:
  • 148 Answers
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Jul 12, 2008
Water will run in machine even when the machine is turned off
A water valve within the washer must be leaking. A test to see which one, close a water supply, either cold or hot and see which leaks. A band-aid solution could be to only connect hot (or cold) water to the one that doesn't leak, select appropriate water temp, hot-hot or cold cold.
Jan 21, 2018 | Washing Machines
Washer leaks water all over when filling. Where is the leak?
If you can spot the location of the puddle when it starts then that would be a big help. So would the make and model, With that in mind, the fill hoses come from a valve in the back of the machine and go to the drum, if the water is hot you can look for the leak in the hot water line inside the machine, if not look for the cold water line if the leak appears in the area under the valves. The other thing is that the machine might have a water hose that flushes the detergent tray, those hoses have been known to come loose.
Jul 14, 2015 | Washing Machines
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
I have a fisher and paykel washing machine.Its started leaking under the machine when its do the rinse.
The leak could be from:
  • the pump
  • one of the hoses that attaches to the pump system
It is likely to be the pump. However, to verify where the leak is coming from do the following:
  1. Make sure the washer is empty of excess water. (Run the Spin cycle, if not sure.)
  2. Unplug the washer.
  3. Turn off the hot and cold water supply taps.
  4. Disconnect the hot and cold water supply lines.
  5. Pull the washer away from the wall a couple feet.
  6. Have a helper tip the washer back toward the wall and hold it up securely for you!
  7. Get down on the floor with a flashlight and look up underneath the washer for the pump. It will have a small fan blade as well as wiring and water tubing going to it.
  8. If you see signs of rust or water drops on the pump, the pump impeller shaft seal is probably leaking. Order a new pump and install it. It takes no tools and about 20 minutes as follows...
  1. Get a roll of paper towels.
  2. Make sure the washer is empty as above.
  3. Unplug the washer.
  4. Turn off hot and cold taps.
  5. Disconnect hot and cold supply lines.
  6. Pull washer away from the wall a foot or two.
  7. Tip the washer back toward the wall.
  8. Have a strong, reliable helper hold the washer in that position -- firmly against the wall.
  9. Get down on the floor. Lie on your back and put your head and arm under the washer (that's why you need a good helper!).
  10. Unplug the electrical wiring to the pump. (The GWL11 has 2 wiring connectors.)
  11. Slide a shallow plastic dishpan under the pump to catch any water.
  12. Find and bend back slightly (don't break it!) the plastic retaining latch that holds the pump in place.
  13. Rotate the pump counter-clockwise about 60 degrees, until it comes free.
  14. Note the angle/position of the pump as you pull it free. This is the same angle/position you'll use when you put in the new one.
  15. Have your helper clean up any excess water that ran onto the floor.
  16. Install the new pump.
  17. Have your helper lower the washer to the floor.
  18. Reconnect the washer to the hot and cold water supplies.
  19. Open the hot and cold taps.
  20. Plug in the washer.
  21. Test the washer with no clothes in it.
BTW - Cleaning all dust out from under the washer a couple times a year should help prevent pump squealing and leaking in the future.
May 30, 2011 | Fisher Paykel EcoSmart GWL15
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Hi. My smartdrive 6.5 kg top load washer pushes cold water up the hot water line while it is filling up. I don't use hot water. thank you
on your machine when you select cold, the hot water valve will open automatically letting cold water thru it.can you connect the hot hose up to a tap to stop the water leaking out? or you can buy a screw on plug from a hardware shop that will cap off the valve at the machine or the hose. sometimes to save a customer money i connect their hot hose to the hot valve then fold the hot hose in half and tape it in that position . this stops the water. hope this helps. please reply for further help if you need it
May 26, 2010 | Fisher and Paykel Washing Machines
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
May 17, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
187 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
