Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity washer not spinning
All of a sudden the washer will not spin... I hear what appears to be the sucking sound of the pump, but no movements
  • lbilan Oct 31, 2008
    I have the same problem. Additionally, the drum ended up being stuck. The tech fixed the drum issue but failed to listen to me to diagnose the spinning issue. Also, the machine shuts off mid-cycle. The timer will say 43 minutes then shuts off (after my clothes are soapy and wet).
  • hollandrm Dec 16, 2008
    I am having a similar problem. The washer turns when it starts which makes me think the belt is not broken. When it is supposed to be spinning really fast it doesn't, just doesn't move at all. When the cycle is done and you take the clothes out you have to ring them out before you dry them? Any ideas on how or where to start to fix it. Husband took the back off and the motor spins by hand and the belt is fine????
    Scholar:
  • 148 Answers
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jul 12, 2008
  • derek martin Jul 13, 2008
    could you please give me a rating,I thank you
Hello! I am having problems with my washer's spin cycle. It appears that the water is staying in Drum
If you unit is spinning but not emptying the water then I would suspect the water pump which is part #134051200. There may be something that has been sucked into the intake of the pump that is keeping it from activating, but you will have to open it up to find out.
Sep 14, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Glacier Stackable upright washer. Washer will not agitate and makes a buzzing sound from the pump that extracts water from the drum. Water collects and remains in bottom of washer.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Dec 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
My washing machine will not spin, it will wash and then make a buzzing sound during the spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Dec 12, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
14 Cycle Front Load Washer Frigidaire
COLGGED PUMP! CALL SERVICE BEFORE IT COST YOU MORE TO REMEDY THE PROBLEM. do not try to use this!
Aug 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Front Load
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
Dec 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
666 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
