Question about Radio Shack 15-2146 Remote Control
Device Code Needed
I just get a new Satellite Receiver from Diretv. None of the 22 codes in the owner's manual of my Radio Shack remote (#15-2146) work. Have additional codes been added since I bought my remote?
  • Anonymous Aug 28, 2008
    i have direct tv and i need the program codes
Sanyo tv code
Posted on Aug 09, 2008
Need a code for hd satellite receiver 550hd from one for all remote
I couldn't find "AB IPBOX" in the satellite codes, but here is the complete list of satellite receivers in the URC 4081 manual. Hope one of them helps.
Setup Codes for Satellite Receivers:
AlphaStar 0772
Echostar 0775, 1005
Expressvu 0775
General Instrument 0627, 0361, 0869
HTS 0775
Hitachi 0819
Hughes Network 0749
JVC 0775
Jerrold 0627, 0361
Magnavox 0724, 0722
Memorex 0724
Next Level 0869
Panasonic 0701
Philips 0724, 0722
Primestar 0627, 0361
RCA 0566, 0143, 0392, 0855
Radio Shack 0869
Sony 0639
Star Choice 0869
Toshiba 0790
Uniden 0724, 0722
Zenith 0856
Feb 10, 2014 | One For All Televison & Video
Need code for dish receiver
0372,0391,0381,0362,0911. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and setup instructions to some popular model remote controls are given.
Mar 11, 2013 | Televison & Video
Kameleon Remote Control #15-2136
If you have done a code search method, and it too doesn't help you, the remote control you have had no setup codes to synchronise with. Give it up, and buy an new one, which has setup codes for your device.
May 10, 2012 | Radio Shack 4-in-1 Kameleon Touch-Screen...
Need code for 15-135 radio shack universal remote for sylvania hdtv
There are a bunch of codes to try for Sylvania here is the list from the uses's manual found at remotecentral.com
10047, 10054, 10154, 10000, 10051, 10178, 10030, 10171, 10092, 11904, 11394, 11314, 11271, 10381, 10187, 10186, 10179, 10159, 10096, 10056, 10024, 10020
If none of those codes work or if you want to avoid trying each one you can also use the code search function, the direction are below.
Searching for a Code
Use the following device code digits to control a specific device:
Code Digit Device 0 Cable / Satellite 1 TV 2 DVD, VCR, DVR/PVR 3 Audio, Misc Audio 1. Turn on your device and, if needed, load media (for example, a DVD). 2. On the remote control, press a device key (TV, CBL/SAT, DVD, DVR, AV1, AV2 or VCR) once; it blinks once. Then press and hold P until the LED blinks twice. 3. Enter 9 9 1. The LED blinks twice. 4. Press the code digit for your device. The device key blinks twice. Aim the remote control at the device and press Power once. (The code for the TV is 1) 5. Press and release the CH+ key continuously, then stop when the device turns off. The remote is sending IR codes from its extensive library to the selected device, starting with the most popular code first. 6. Press Power. The device should turn on, then press P to lock in the code. If the device does not turn on during step 6, slowly press and release CH- to go back through the codes, press and release P when the device turns on.
Jun 08, 2011 | Televison & Video
I have a Radio Shack 6 in 1 remote (15-1923) and a Sansui RZ-3000 receiver. Had to change the batteries and lost the connection. What code can I use to make this work again?
The Sansui receiver should be programmed manually. Turn on the receiver manually, then press and hold Setup until the light turns on. Press the button that you want to control the receiver. The light will blink once. Aim the remote at the receiver and press On until the unit responds. When the device turns off press ENT within 5 seconds. If you miss the code, press repeatedly Last and then On until the receiver responds. Then press ENT. Check if the code works. If it doesn't repeat the code search but wait longer between key presses.
To record the code, press and hold setup until the light turns on. Then press the device control button. Then press 0-9 individually (wait a few seconds between key presses) until you see the light blink. That will be the first digit in the code. Repeat the 0-9 sequence for the second and third digit in the code.
Radio Shack has the code list and manual here: http://support.radioshack.com/support_video/42245.htm . Sansui CD player, TV and VCR codes are listed in the documentation.
I hope this helps.
Mar 02, 2011 | Televison & Video
Remote turning on of answering device
I'ld consult your owners manual orgo to RS's website and get a PDF version
Jun 23, 2009 | Radio Shack 3822 Digital Answering Machine
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Code needed
Here's the link to the Radio Shack product document support. It has all the codes and how to info.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502200_PM_EN.pdf
Oct 19, 2007 | Radio Shack 15-2200 Remote Control
Radio Shack 15-2146 Remote Control Logo
164 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
