Question about Rival CF275 Deep Fryer
The casings to the heating element of my rival c2f725 is melting there is now a hole in it
  • 57 Answers
WHAT I WOULD ADVISE YOU TO DO IS NOT REPAIR IT AS THIS IS HIGHLY DANGEROUS I WOULD RECOMMEND YOU TO SCRAP IT AS IT IS MORE THAN LIKELY THAT THE ELEMENT HAS LOST RESISTANCE AND COULD CATCH FIRE.
Posted on Jul 17, 2008
How to check heating element
You can sometimes see the burnout of an element. In some cases it will actually burn a hole or melt a spot in the outer lining of the element. Sometimes it shows nothing. In that case it can only be tested with an ohm meter... Normal reading is approx 15 to 20 ohms. No reading at all means its burned out.
Feb 28, 2015 | Kenmore 91112 / 91114 / 91117 Electric...
Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
My steam mop model jc-206 shows ared light and switches to between red and green but does not produce steam.
There is a tube that goes between the pump and the heat element,I just took one apart and the tube was melted therefore prevent any steam getting to the bottom of the steam mop.Also if it isn't melted or cut the element could be blocked,take a small piece of wire and clean out the hole in the heat element.
Dec 17, 2010 | Vacuums
I a Westinghouse dishwasher 920 and a plastic spoon fell onto the element while it was on and its melted the spoon on the heat element and i cant remove it. how do i replace the element i am a motor mech...
Break as much of the plastic off as you can and just let the rest melt off or melt it with a solder gun . won't hurt anything. If you want is easy to replace just hall machine from hole and tilt back remove the wires and the nuts holding it on .
Dec 03, 2010 | Westinghouse Dishwashers
Hole developed where heating element enters near temp guage, is this unsafe? thanks
Yes, DO NOT operate a microwave with any holes in the case or glass... this is very dangerous!!
heatman101
Sep 25, 2010 | Rival Microwave Ovens
I heated the fryer without oil so I am assuming I ruined the heating element because it doesn't heat. My question is ca I get another heating element?
i would have to say no i cant find online rival selling individual parts for these models. But i wouldnt assume the heating element is blown. If you feel you can take it apart look and make sure that all the wires are properly connected to the heating element and that none of them shorted out.
If thats not the case then there isnt much you can do as this is not a commercial/industrial model. I know no one likes to hear that.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Rival CF156 Deep Fryer
A piece of plastic spoon melted on heating element. Is there a way to clean it off.
Make sure the heating element is cool. Remove as much of the melted plastic off that you can by hand first. You can use a straight edge razor to lightly scrape it off. When you have most of the material removed, get some fine emery paper or steel wool to finish removing it. DO NOT use anything that is so abrasive that it penetrates the outer shell of the heating element. Once a hole forms and water gets inside, the element has to be replaced. I hope this helps you.
NOTE: I would not recommend using any kind of cleansers as they tend to leave residue.
Feb 08, 2010 | Dishwashers
Heating element won't heat. Control light comes
your element is shorted
since the elemen t is welded and fitted to the bottom of the pan it can be fixed but should not be
my advise get a new one
rival will just say it has water damage
Oct 08, 2009 | Rival S16RB Electric Skillet
Rival CF275 Deep Fryer Logo
27 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
