Question about GE WBSR3140DW Top Load Washer
Washer wont drain water
My ge washer will spin but it wont rain the water. it took the clothes out and set it on spin to let it drain on it own but the water wont drain out. what can i do? can i fix it myself? or do i need to call someone? please help asap!!!! thanks!
Mary
  • Tyler Durden
    Tyler Durden Jul 13, 2008
    Chad_Fix_it was right. I had that same problem and I followed those instructions and everything works Great now! Thnx Chad!
  • Anonymous Jul 24, 2008
    washer not draining
    Scholar:
  • 148 Answers
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Jul 13, 2008
  • derek martin Jul 13, 2008
    could you please give me a rating,I thank you
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
The spin cycle spins very slowly and the clothes come out extremely wet (drippping wet). How do I troubleshoot this problem?
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Washer will drain but not spin out clothes
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 01, 2009 | GE WBSR3140DW Top Load Washer
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
My font load washer wont spin or drain
You will need to to replace the inverter
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Water not draining my ge washer will ot drain the water. it is spinning but not draining. i took out all the clothes and set it to spin and drain but it wont drain the water. what to do? can i do it...
Jul 12, 2008 | GE WBSR3140DW Top Load Washer
GE PROFILE
It sounds like your drain hose is kinked or blocked, or maybe the pipe that the drain hose drains into is blocked. Somehow water is now being allowed to get out of the machine at the end of the cycle and is staying in the machine. Check those hoses and pipes.
Jul 11, 2008 | GE Profile Harmony DPGT750EC Electric...
GE WBSR3140DW Top Load Washer Logo
300 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
