Question about Maytag Refrigerators
Maytag refrigerator modelMFD2560HES MAKING NOISE STARTING TO THAW FREEZER
Ran diagnostics program trouble cleared...has happened before..suspect power brownouts.
Posted on Jul 13, 2008
Freezer temp is below zero it is minus 2.00 will not adjust.
Negative 2 degrees is a good temperature for freezers, but if you want it warmer, raise the thermostat up (warmer temp) In the refrigerator section, & open damper (or set the adjuster knob in the back of the freezer to warmer). If the motor is making a loud noise, it may be hitting ice built up from the evaporator...thaw out.
Feb 28, 2015 | Refrigerators
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge working off/on
If the noise was coming from the compressor when it was cutting off or starting, it was the internal mounts of the compressor and the compressor will have to be replaced. If the noise was a fan, it may have stopped. One is in the freezer behind the rear cover and one is underneath where the compressor is behind the cardboard cover.
Dec 31, 2009 | Whirlpool ED2FHSS Side by Side...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerator not cooling
the clicking noise is probably the compressor srart relay opoerating but the compressor not starting. compressor faulty and an expensive repair
Sep 03, 2008 | Maytag MBB1956GES Bottom Freezer...
Clicking noise on and off every 2-3 mins
compressor has locked up -- call maytag -- if its less than 5 yrs old it might still be under the sealed system warranty -- which means its fixed free of charge.
Dec 13, 2007 | Maytag MBF2256H Bottom Freezer...
Refrigerators Logo
319 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
