When i close a window on my computer the computer shuts down each time and i have to restart the computer
    Scholar:
  • 58 Answers
Hi.
I'm a Microsoft Windows lover, but i have to admit what many Linux lovers say " if Windows don't give you any trouble its something wrong with it "
If i were you i would consider a Windows Reinstall, because trying to fix that can drive you crazy.
Regards.
Posted on Jul 12, 2008
How to restart a pro line Intel sv.701
If you have Windows
Left-click START or the round blue Windows icon at bottom left of screen.
Or press the Windows key at bottom row of keyboard.
Left-click the white right-arrow symbol next to "Shut down".
This drops down a choice menu.
Left-click "Restart".
Now sit back and watch the magic happen.
Otherwise to shut down click the Shut down bar in Start window.
Or in case the PC freezes / hangs press "Power" button.
If an application hangs, stopping your computer, you can also try close down the app in "Task Manager".
Press Ctrl+Alt+Del
Wait until the Task Manager options window pops up on screen.
Left-click "Start task Manager"
Left-click "Applications"
Shut down the app then exit TM.
Reboot to refresh memory.
Dec 04, 2017 | Intel Computers & Internet
THE CURSOR WONT MOVE WHEN YOU ROLL THE MOUSE CANT CLOSE WINDOWS DOWN
Hold in the main power on button until the computer shuts down -windows will automaticly safley shut down .
once it shuts down restart it and hopefully the mouse problem will also be fixed
I hope this helps
Andrew a
Mar 28, 2011 | Computers & Internet
On/off switch keeps blinking
The on/off switch usually blinks if you have put the computer into hibernate instead of shutting down, or with laptops closed the lid before it has fully shut down. Restart your computer and if it says resuming windows instead of starting windows then this is what has happened.
Hope this helps
John
Dec 03, 2010 | Computers & Internet
Hi. my computer won't log off, shut off, or let me close a tab/window What do i do??
press the Ctrl+Alt+Delete at the same time... depending on the computer and its age varies how long it will take to bring up this "task manager" window. Then you can click on the program thats open that locked your computer up and click "end task" to force it to close. Or you can simply press and hold the power button on the comp and force a shutdown but then you can lose anything you were working on that you didnt save. Simply restart it after it shuts down. Good Luck
Aug 14, 2010 | Computers & Internet
Pavilion dv7 keeps shutting down
  • This may not fix your issue but its worth a try ...let me know how it goes
  • If the computer appears to shutdown and then attempt to restart without displaying an error message, do the following to disable the automatic restart on error setting.
    1. Click Start , right-click Computer , and then select Properties .
    2. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
    3. Click Settings in the Startup and Recovery section of the Advanced tab.
    4. Deselect the Automatically restart checkbox under System failure .
    5. Click OK to close the Startup and Recovery window, click OK again to close the System Properties window, and then close the Control Panel window.
    6. Restart the PC.
    Disabling the automatic restart setting allows time to view the error message that displays on the screen. Contact the manufacturer of the program or device that is causing the error for specific information about the error message.
  • Jan 21, 2010 | HP Pavilion DV7-1232nr Notebook
    Computer re-starts when i want it to shut down or sleep
    You should check to see if there is a setting time where the computer installs updates, because the computer may be updating at a certain time and then restarts to finish the update. Check the setting to you might also have the computer restart every so often. hope that this helps.
    Jan 08, 2010 | Dell Inspiron 1525 Notebook
    I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
    There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
    The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
    Try re-installing the non-responsive program and see if your computer can shut down normally again.
    Aug 07, 2009 | Acer Computers & Internet
    Toshiba Satellite A55-S306 doesn't come out of hybernation
    Turn the PC on, when it is booting up, keep hitting "F8" until windows boot options come up, choose "Safe Mode" and then once it boots into safe mode fully, go to the start menu and choose shut down. After it shuts down, turn it back on and it should go back into normal mode. From now on, don't use Hibernate, its buggy and has been since XP.
    Feb 02, 2009 | Toshiba Satellite A55-S306 Notebook
    Personal Data File did not close properly
    Hope this solves it for you! Here's the official word from Microsoft:
    If you receive one or more of these error messages, you may experience performance issues until Outlook finishes the reconciliation process for the .ost file or for the .pst file. The following gear icon is displayed in the status bar while Outlook checks the data file in the background: Collapse this imageExpand this imageol2007gearicon.jpg When this icon disappears, the .pst file or the .ost file is reconciled. If you exit Outlook while the gear icon is present, reconciliation must restart the next time that you run Outlook. We recommend that you leave Outlook running until the gear icon disappears before you exit Outlook.
    An incorrectly shut down .ost file or .pst file may occur for one of the following reasons:
    • Antivirus scanning of the file
    • Forced Microsoft Windows shutdown before the Outlook.exe process shuts down completely
    • Outlook add-ins
    If you see this issue frequently, and you have to exit Outlook shortly before you shut down your computer, it may be better to shut down Windows while Outlook is still running. We recommend that you do this instead of exiting Outlook and then shutting down Windows shortly after that.
    Dec 26, 2008 | Microsoft Office Outlook 2007: Windows
    After i load ssp2 my computer does not open window program
    What is 2.2 frame?
    Do you mean .Net framwork 2.2 update from microsoft?
    Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
    .Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
    Continue to update you're windows.
    Please let me know if this has helped.
    Good Luck!
    Mike
    May 08, 2008 | E-Machines eMachines Desktop PC
    Computers & Internet Logo
    60 people viewed this question
    David Payne
    David Payne
