Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Bleach dispenser It has been recomended that we check the flush solenoid in the bleach dispenser, how do we do that?
  • 481 Answers
You can't unless you know how to take the machine apart, know which solenoid goes to the bleach dispenser and have a ohm meter handy. whoever said that might have thought you were a repair technician or in training.
Posted on Jul 12, 2008
Water is still in my liquid bleach dispenser after load is finished. is this normal?
If it is just water then it could be OK. Most companies use a water stream to flush the bleach and also the fabric softener out of the dispenser systems and into the washer tubs. Some water left over is probably normal as long as the bleach or fabric softener has dispensed.
Sep 19, 2014 | Kenmore Oasis153; Agitator 4.5 cu. ft....
Bleach left in washing machine dispenser
Remove and clean the drawer of the dispenser
Mar 28, 2014 | Kenmore Oasis HE 27082 Top Load Washer
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Duet Bleach dispenser not working - dispenser motor working properly
It sounds like the solenoid output of the bleach dispenser may not be reacting to the step motor that cycles it...Also check for a clog of dried out stuff just below the dispenser screen.
Dec 31, 2012 | Whirlpool duet Washing Machines
Bleach will not dispense
You will need the Service Manual for reference. Sears Parts Direct for reference.
Do you have water flow to the dispenser? You can turn on the dispenser water valve in Service Mode and check for operation.
Non technical troubleshooting would be to enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Bulky Items Key. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Bleach dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach dispenser valve.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
The Part Number for the Dispenser Valve is 25001043 Google for best price. Post back if you have questions..........Rich
Pic of the valve on the work bench;
May 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Softener or Bleach will not dispense. Any idea how to fix this problem? I have Neptune TL washer FAV6800AWW.
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softner dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open or loss of 120VAC from the Control Board to the valve. Do the same for the Bleach Dispenser Valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or find best price. Before I would order any parts you need to isolate the fail point, this could be a Control Board issue or machine wiring harness issue.
Did both reservoirs stop flushing contents at the same time or different fail dates?
Rich
Apr 01, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Bleaching subsequent loads
I'm no repairman but here's a coupla thots:
1 - try running an empty load after bleaching. Save money and just use cold water. First add a few cups of water to the bleach dispenser to help flush out the old bleach that might remain, then run it.
2 - lemon juice is naturally acidic and should neutralize the bleach. You could add some to the bleach dispenser and do the above. Maybe mix a half-cup with a few cups of water and put in the dispenser, then run it. (Lemon juice [or vinegar] is good thing if you get bleach on your hands, too.)
OF COURSE -- Test to see if this works with a couple colored rags before running any good clothes through.
3 - How about using oxygen bleach alternatives (color-safe bleach) instead of regular bleach?
I suppose there could be a problem with your dispenser, idk....
Feb 20, 2009 | GE WBSE2090A Top Load Washer
Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
Jan 30, 2009 | Whirlpool GHW9400 Front Load Washer
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
42 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
