Question about GE Washing Machines
For the second time ----- My topload clothes washer is soggy wet at the end of the process. Spin and drain was tried twice. Clothes still soggy. During spin and drain cycle basket does not spin.
  • 2,071 Answers
Click below for more information:
handy, concise punctuation guide; go ahead a bookmark it now
pour out your love-libation to the Samurai Appliance Repair Forum,
start a new topic in the Laundry Appliance Repair Forum
Posted on Jul 12, 2008
    Guru:
  • 859 Answers
Does the machine spin in any other cycle and does the problem persist whether its run in Normal mode, Permanent Press mode, etc?
    Scholar:
  • 148 Answers
Try your door switch first,and if ok its the timer
  • derek martin Jul 12, 2008
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
My machine is spinning, but clothes are still very wet, have to drain and spin at least twice to get them dry enough to put in the dryer
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Feb 08, 2011 | GE Washing Machines
Clothes are left soggy after the wash cycle
You could try looking into the water pump, if its bad replace. If its not getting a signal to operate you may have bigger issues. Also is the spin cycle happening as it should?
Apr 16, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Soggy wet clothes, doesn't appear to spin out the water
Hi!
This usually happens if the drain pip is clogged...
There are two types of drain 1. By garvity 2. By Pump....
If its by gravity please ensure that the entire drain pipe is facing downwards with NO upward bend or loop as this would stop the water from flowing out entirely ..hence leaving the clothes wet.
If its by the pump... again check if the outlet end is not clogged or stuck too close to the wall or any other object....
Try and see if you can hear the pump motor.. may be that the pump is not working till all the water is pumped out.
Regards
Berry
Feb 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
My GE washing machine does not spin the water completely out of clothes. Garments come out very soggy and have to be wrung out by hand before putting them in the dryer. Any ideas?
My washer was pausing during the rinse cycle, sometimes leaving the clothes very wet as well. I pulled out the filter underneath the lower panel, it was packed with coins, etc. Has been running fine (draining) ever since. Hope this helps...
Oct 01, 2009 | GE WSXH208A Front Load Washer
I spin my clothes twice
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
May 27, 2009 | Whirlpool Model WHP1500SL
Wet clothes after spin cycle
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Jan 12, 2009 | Kenmore 43142 Front Load Washer
10yr whirlpool toploader wash machine no spin/agitat. but works?
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Jan 08, 2009 | Whirlpool Washing Machines
Washing Machines Logo
238 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
