Question about Linksys PrintServer for USB with 4 port Switch: PSUS4 (NTSVLS0PSUS4) Print Server
Computer not recognizing print server
My print server was working perfectly. Then, out of nowhere, I get some error message something like "print server failed"
I don't believe it is broken. I'd never touched any settings nor were any connections changed. The print server is connected to my computer thru a router.
Also, I uninstalled files and drivers that came with the setup disk.
When I tried to reinstall, during setup at the step where the screen gives me the choice of setup wizard or user install, choosing either gives me no device. It acts as if there's no print server connected. I've checked and rechecked and it is powered and connected. The green leds are on.
Please Help!!!
    Scholar:
  • 132 Answers
If you connect your printer directly to your computer, were you able to print? Make sure that there is no firewall enabled in your computer (Double check windows firewall or any personal firewall, that could have been enabled).
Posted on Nov 09, 2008
My HP Deskjet F380 has the latest printing software installed; it spools and is attached to my laptop in the correct USB port; but it doesn't print. The message is "no connection." It printed...
Verify that the USB connection is fully inserted in the back of the printer itself. If all is well there, try to think if you've run any updates on your laptop recently, or installed any new software that could be conflicting. If yes, try removing the new software or recent updates, and try a test print. If this still does not work, try disconnecting the printer, powering down your machine, starting it back up and then reconnecting the printer to the USB port. Sometimes you have have a glitch in the USB port that causes your computer to stop recognizing a device seemingly out of nowhere. If none of the above seems to help, it might be as simple as a USB cable that's become faulty. Hope this helps!
Nov 19, 2010 | HP DeskJet F380 All-In-One Printer
Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
Sep 22, 2007 | D-Link DPR1260 Rangebooster G...
Will not work unless I disable my current wireless connection internet connection. Can not get computer to recognize wireless print server.
You need to use the SSID of the wireless router on the print server. Any wireless security applied to the router must also be applied to the print server. Otherwise you have two seperate wireless networks.
Aug 30, 2010 | D-Link DP-G321 Print Server
Until a few days ago my Model X3550 operated perfectly, now the unit will not respond to print command, although it will still copy and scan and perform all other functions. Simply will not print, get...
unplug printer. uninstall the printer drivers. restart computer. when desktop comes up, plug in USB for printer. Windows should recognize the printer. If not, try a different USB cable.
Feb 04, 2010 | Lexmark X3550 All-In-One Printer
It has appeared out of nowhere
500 Internal Server Error
Sorry, something went wrong.
A team of highly trained monkeys has been dispatched to deal with this situation. Please report this incidentto customer service.
Also, please include the following information in your error report:
_zMKEvZPV3e1d4MeCvjFSTmsrchea_WxdkvDyFoQJVEbkONEym2tO_-r1_m6
7vPXNgmnr9NQYJ8vYm9eDWqjSKPGPC9WG894fTdd-zI6HX5XKIfG9Gn7Xzl1
Apr 01, 2009 | YouTube Videos
Server-error-service-unavailable on my hp printer
See this link, I had the same problem and it fixed mine.
http://slayo.com/hp-printers-mac-os-server-error-service-unavailable-or-error-1282-message-when-adding-a-printer-in-mac-os-x.html
Mar 04, 2009 | HP Photosmart C3180 All-In-One InkJet...
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Print server configuration in canon mf4150
I had the same problem. After many hours of trial and error, I got two XP laptops and a Vista desktops configured. Be sure to use the latest firmware from Dlink. Disable all s/w firewalls. In my case Norton Firewall from Yahoo was a problem. The Vista PC was configured to print within 30 mins and the XPs took a while. I couldn't get the print server to appear in the My Network Places A couple of the guys who left comments on the product at Newegg actually have a good solution. The solution involves setting the printers up as local printers with standard TCP/IP ports that point to the IP address or the URL ("dlink-"6_last_digits_of_MAC_ID) and USB port number 9100-9103. You can google how to set up local printers w/ TCP/IP connections with USB ports on the internet. Note the Scanner will not be recognized but at least you can print on MF4150.
Dec 12, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Net Gear PS121 print server, prints test page but not word docs
It's a driver problem not installed properly on the XP machines. Here's what you can do. Install first the driver of the printer directly to the XP machines. Then try to re-do the smart wizard installation.
Dec 02, 2008 | NetGear WGR614 Router
Can Not Print to HP LJ 1020
hook the print server directly to the computer and program it with a static IP address.
than create a new printer port in add printer. Than setup the printer and use the port you just created and it will work fine
Dec 14, 2007 | D-Link DP-300U (DHDP300U) Print Server
Computers & Internet Logo
225 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
