Vornado Circulating Fan
Problem for Vornado Circulating Fan
HOW DOES THE SPRING RESEAT FROM BASE TO FAN ON VORNADO 750?
By tms331 on Jul 12, 2008
My V-750 was packed with dust clogs throughout. I took the front grill and backside cover off, and meticulously worked with tweezers, a pick and compressed gas to clean it out. I was astounded by the huge amount and huge chunks of dust that I got of it. After cleaning the blades, grill and cover and putting the grill and cover back in place, I plugged it in, turned it on and it began making a very loud noise, like metal banging and clanging together. I thought perhaps it was ready to taxi the room and fly, so I shut it off.
I took it apart today to check for loose/broken wire in the motor or any other obvious problem. Everything looked OK, so I was able then to clean out all the dust I hadn't seen prior -- a bunch of it. I have it reassembled to the point of attaching the base to the fan.
I am puzzled as to the proper placement of the spring that sits on the base column at the top and seems to work with the niche cutout in the column. I want to make sure it is properly installed.
Can you please advise me as to do that? I appreciate any aid you can give me.
Thank you very much,
Tom (tms331@sbcglobal.net)
Best Solution
posted on Mar 23, 2009
Helpful)
reknuj
Rank: Apprentice
Rating: 92%, 3 votes
Many Vornado models have a lifetime warranty - you just contafct them with your serial number and they check the warranty on your model and provide and return authorization label/number.
Send it back and they repair and return to your with a week or so.
Go to tehir webiste http://www.vornado.com/Default.aspx?ISC_PageName=Manuals-Warranty
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Vornado Circulating Fan
Questions and Unsolved Problems for Vornado Circulating Fan
Do you recommend Vornado Circulating Fan?
Answer
Answer
Model 280ss fan has started miking noise when running
Answer
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've... (More)
Answer
How do I open Vornado fan (model EH1) so that I could clean fan blades?
Answer
I have a vornado fan on a pedistal that's about 13 years old. Have to twirl the blades manually to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vornado Circulating Fan:
Top Electric Fan Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Electric Fan Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
