Question about Cuisinart DLC-2011 PowerPrep Plus Food Processor
Does DLC 835tx fine grater fit the dlc 2011n?
  • 8,596 Answers
The pusher assembly wont go down and engage.food processor Cuisinart DLC-2011N
the safety tab is engaged. UNPLUG the unit before reassembling the lid. check it for proper operation before you put power to the unit. call customer service for expert guidance
Oct 10, 2017 | Cuisinart Food Processors
Need instruction manual Cuisinart DLC2011NC
Hi Theresa: Your Instruction and Recipe Booklet for the Cuisinart DLC-2011N Premier Series 11-Cup Food Processor may be downloaded in PDF from the following link:
http://www.cuisinart.com/share/pdf/manuals/dlc-2011n.pdf
Jan 04, 2012 | Cuisinart DLC-2011 PowerPrep Plus Food...
My food processor is ancient and works like a new one. but broke a piece (small nick) from the bowl. All blades work fine but cheese grater. The only thing I can provide for id number is CFP 9A. This is on...
You should probably not use the thing anymore. The type of plastic they used back then gets very brittle over time, and there's a chance that the bowl could shatter while you're using the processor. There's a chance that if that happens the safety switch will stay engaged and the unprotected blades will keep spinning, right where your hand is. It happened to me.
Sep 17, 2009 | Cuisinart DLC-5 Food Processor
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Grating
Any of the disc blades require the use of the detachable stem. The official "Fine Grating Disc" (which doesn't normally come supplied with the food processor) is mainly for grating cheese, but the shredder disc that comes supplied with the food processor will do the job for you.
Here is a link to the manual:
http://www.cuisinart.com/share/man/57_man.pdf
-Tha Mp3 Doctor
Apr 25, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
How to attach Cuisinart blades DLC 8 to DLC7 stem
The DLC-8 blades and the DLC-7 blades are not compatible. To attach the stem, first attach the stem to one of the compatible blades - the stem should day "DLC-7" for the DLC-7 blades - by inserting the first two tabs of the stem into the first two ridges of the blade connector - the left-most tab should be sticking out past the end of the blade connector - then slide the stem into place so that all tabs fit securely into the blade connector. Next, place the end with the blade up and insert the stem into the middle of the workbowl. There is a video for all Cuisinart food processors on the Cuisinart website.
-Tha Mp3 Doctor
Jan 01, 2009 | Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-2011 PowerPrep Plus Food Processor Logo
66 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
