Question about Dell Inspiron 1300 Notebook
Will not power up
I have a dell inspiron 1300 and it will not power up the lights come on then they go off. One light stays on and blinks every 2 min. I tried another battery but nothing happens.
  • 1 more comment
  • willene Jul 13, 2008
    No I did not get a dell logo at all the screen does not come on.
  • tomcb2000 Nov 14, 2008
    i have a Dell Inspiron 1300 the power light stays on for about 4 seconds and then goes off i get no screen image or beeping of any sort
  • Lee Edwards May 11, 2010
    Do you get a post screen at all or the Dell logo ?
    Genius:
  • 2,028 Answers
This could be a bad memory chip. Try taking out the memory, putting one or the other in and starting, then changing them out and starting. If it's not a battery or memory, then the problem will most likely be with the motherboard. You will need to take it in for a professional diagnostic in order to find out whether it's a replaceable component on the board or if you will need a new board.
Posted on Jul 15, 2008
Last time i used it the screen froze i shut it down when i powered it back up all 3 lights at top blink on then off bu only the first 2 lights at the bottom comes on and the screen stays black what is the...
Did you remove the battery, drain the power, put the battery back in and trying to boot up? Usually this will fix it. If not, post back here for more help.
Dec 06, 2010 | Dell Inspiron 1300 Notebook
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Thank you for using FixYa.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 12, 2010 | Dell Inspiron 1300 Notebook
Inspiron 1300 PC Notebook: I can not start my Dell Inspiron 1300 , when i plu...
adapter should be fine..if light comes on adapter should be good...leave battery out of the system...just use adapter and when starting system up tap f12...see if u can see this menu..if not try a external monitor to see if u can get a image..if so run the diagnostic..if still no image or no external monitor it may be a mb
May 06, 2010 | Dell Inspiron 1300 Notebook
No power leds. My Ac adapter is new with the right voltage coming out. I have to keep on unplugging the power cord then the green light comes on my Dell Inspiron 1300
If the adapter is new or OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Mar 06, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 1300 display
Does this happen regardless of operating system state? (e.g. if you interrupt normal booting to windows)? You could try booting from e.g. linux live cd to see whether the issue is operating system-specific or if it's caused by a hardware problem.
I've seen very similar symptoms on several Thinkpad T41s where ATI graphics chips were failing, I hope it's not the case with your dell.
Good luck,
Raf
Nov 09, 2009 | Computers & Internet
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1300 does not switch on
try unseating and reseating the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion.
If this doesn't do it then take out the hard drive and dvd drive then turn on ht laptop.
If after all of these steps you still don't get video then the motherboard is bad.
Aug 08, 2009 | Dell Inspiron 1300 Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 Notebook Logo
120 people viewed this question
Alun Cox
