I am trying to set up this Linksys Wireless G router WRT54G2. When i get to the last step I get an error 322 stating your new router appears to not be connected properly. I have checked the connections several times and everything appears to be connected properly. I have access to the internet, but the router is not configured.
  • 50 Answers
Try disabling the windows firewall
Launch your web browser and type
192.168.1.1
see if you can get in and manually configure it from there
Posted on Jul 12, 2008
Solution for error 322
From the computer you are trying to configure the router from. Make sure you have an ethernet cable plugged in from the computer to one of the four numbered ports. You do not want one plugged into the wan/uplink port, this port is to be connected to your cable or dsl modem. Also open a command prompt, press the windows key and type "cmd" <enter> then type "ipconfig" <enter> scroll up and look for an IPv4 address it should start 192.168.x.x. If it starts with 169.x.x.x then your computer did not aquire an IP address via DHCP. If it shows as 169.x.x.x type "ipconfig /renew" <enter>. If it tells you, you don't have permission click windows key > All Programs > Accessories, right click on "Command Prompt" and click "Run as Administrator and repeat the last step.
Comment back if you need more assistance.
Nov 20, 2011 | Cisco Linksys WRT54GS2 Wireless-G...
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Following CD perfectly 5 times and getting Error 322. I have internet through my cable company and not a phone line.....is that the problem????
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 16, 2010 | Linksys WRT54G2 Wireless Router
Setup difficulties. Can't complete step 4/4
May 02, 2010 | Linksys WRT54G2 Wireless Router
I receive the 322 error when I´m trying to install my new WRT160N v3 Router, by Cisco.
I think you are trying to install the router using the CD. This CD has a bug. Even if your computer is connected to the router , it will say the computer is not connected to the router and it will give you error 322 or 321.
You can install the router without CD also.
Make sure that your computer is able to go online through the modem only.
connect the computer and the modem to the router and open the set up page of the router.
On the set up page you can change the settings of the router according to ISP.
Click Here for step by step instructions
Feb 01, 2010 | Linksys WRT160N Wireless Router
How to find security code for linksys WRT54G2 to
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 28, 2010 | Linksys WRT54G2 Wireless Router
Cannot connect to the router
Right click the network icon in the system tray. Click "repair."
If that doesn't work.Power off netbook, router, modem...
Turn on router. Then Modem. Then netbook in that order waiting 1 minute interval between each.
Everything should be functioning ok.
Dec 21, 2009 | Linksys WRT54G2 Wireless Router
Error 322
When you try to set up the router using the set up Disc, sometimes you will get this error 322. This error says that there is hardwired connection between the router and the computer. Even if you connect the cable between the router and the computer , you will get this error message.
You can try to set up the router manually. It is easy.
Click Here for step by step solution
Nov 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless adapter and linksys wrt54g2 router not seeing each other
its possible that the wireless card does not have the correct wireless settings.
Open the linksys wireless monitor on your wife's laptop.
Go to the profiles tab, highlight the default SSID then click on edit at the bottom. It will search for the wireless network, from the list of networks that it will show you, click the name of your wireless network, in if the network is secured you will be ask to put in your network key. Then click connect. Then it will say that you profile was successfully configured. then click connect to network. It will take you back back to the screen where you saw no association to the access point, check if you will now get a new message. On that same screen click the more info button at the upper left hand side. Check the IP address it should be 192.168.1.x. If you have that IP then you can test if you will be albe to get online.
if you still have any problem just reply to this post.
May 21, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Open Questions:
Support - Storage Solutions - Toshiba'call +1888784-9316 Toshiba is known to be a world class innovator and high technology product leader globally with its 24x7 major subsidiaries and affiliates worldwide. Toshiba launched their first laptop computer way back in 1985 and since then they have managed a record worldwide cumulative shipment of more than 100 million Laptops at Financial Year 2010. Toshiba laptops are sought after because of its quality and superior performance. Regardless of the superior features and all the convenience, you can easily be denied support by Dell Support for any issues that could mess up with your critical data backup, recovery and security. OS crashes are one of the major reason for critical data loss. The other contributors for data loss are accidental data deletion, Virus Attack and natural disasters. Unless, you have an updated backup, you can very well assume that you may have to part away from your precious data. DataAlign takes control of such situations and helps you Toshiba Support backup your data and restore it as per your requirements. DataAlign lets you select backup schedules and it then runs automatically as per the configured schedules. With Automatic Backup protection, DataAlign gives you peace of mind when it comes to data backup and restore. DataAlign's affordable TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus computer. And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any Toshiba Customer service issue that you may face with your TOSHIBA product. Toshiba Help Desk Number 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 26, 2018 | Dell Computers & Internet
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
