Question about Motorola Mobility H700 Wireless Headset
H700 headset person on the other end cannot hear me - I tried adjusting volumes - no use
  • rleon914 Nov 18, 2008
    I have the same problem. It never happened before. I will give this a try, although it is hard to adjust the boom away from my cheek.
  • 30 Answers
It could be that the headset has been muted some way. To mute or unmute the headset, tap both volume buttons on the unit at the same time.
Posted on Apr 03, 2009
Make sure that the tip is not resting on your cheek. That is were the microphone is in that pin hole, adjust the headset so that it stays off of your cheek
Posted on Jul 15, 2008
How do I adjust the volume so that a listener can hear me better
Hi
Volume button is shown in below image IHighlighted)
You need to assign the volume button that is which one is down and which one is up button
1.Turn the headset power off.
2.Press the Call button until the indicator
light becomes steadily lit in purple, then
press the Volume button you want to
assign as the "volume up" button.
Thank You
Sep 02, 2010 | Motorola Mobility H700 Wireless Headset
Caller unable to hear me while using the H700 headset.
Hi there , to solve this proble since you have the headset over 18 months you need to change the internal battary the life time for these handset battery up to 24 months try to replace it by take it to cellphone shop and im sure you be happy.
Nov 30, 2009 | Motorola Mobility H700 Wireless Headset
I can hear the person on the other end but they can't hear me.
To mute or unmute the headset, tap both volume buttons at the same time.
Mar 29, 2009 | Motorola Mobility H700 Wireless Headset
Hearing from Motorola H700
good morning!! ive been thru this before, try tapping your phone volume while your talking to your party, it shold be seen on your phone screen as earpiece volume than turn it up and when you have the volume where you want it dont forget to tap the set on your phone, another prob i had was some times there is a small protective plastic film on the ear holes on the tooth and one on the mike sometimes, i could hear my party but they couldnt hear me until i discovered that lil peice of plastic. remember your key codes are either 0000 or 1234. good luck m.m.
Jan 26, 2009 | Motorola Mobility H700 Wireless Headset
Earpiece volume on my motorola h700 is low.
while talking to your party try the volume on your phone, it should come up as bluetooth or earpiece volume if it does just turn it up and dont forget to hit the set button. good luck m.m. p.s. some times the volume isnt set at the factory. im fighting that problem now on two of my seven h-700s. this may be a solution it may not im letting you know my experiance as best as i can.m.m.
Jan 22, 2009 | Motorola Mobility H700 Wireless Headset
People are having trouble hearing me with the h700
Canuck703 Has the same problem people can't hear me but I can hear them really good on my motorola h700. Please help
Nov 18, 2008 | Motorola Mobility H700 Wireless Headset
Problems w/H700 bluetooth
Try taking a small needle and gently clearing out the mike hole near the end of the boom. Anything I am outside and sweating a lot mine will clog up and I have the same trouble until I clean it out and then it's fine. Do not insert the needle in very far, all you need is to clear the outside opening a bit.
Jun 20, 2008 | Motorola Mobility H700 Wireless Headset
Problem with Motorola H700 Bluetooth
rhondarenee: If you're using a Motorola RAZR V3, the problem is the cell phone. Also check the volume buttons on H700 that sometimes it goes the volume all the way down. It is a common unnoticed situation. SithPitt
Jul 04, 2007 | Motorola Mobility H700 Wireless Headset
H700 headset can't hear me!
Push both volume buttons at once to turn Mute off. You should hear two beeps, ascending in pitch to indicate mute is off. If they go down in pitch mute is being turned on.
May 09, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
314 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
