My samsung 50'dlp tv was blacking out and had sound,bought new lamp, and still blacking out after a few minutes. the fan operates fine. what could be my next thing to check and how. James
  • jrjefferson0 Jul 13, 2008
    Gopi 20 Sorry for sounding lame but were do I check for voltage problem and how? James
    Master:
  • 848 Answers
You are having voltage problem .........check whether your voltage regulators are working properly .......
Posted on Jul 13, 2008
  • 19,396 Answers
Check the small pcb board powering the lamp.
  • Ginko
    Ginko Jul 13, 2008
    It can also be a problem with PSU board, do you get any led flashing after it turns off?
  • Ginko
    Ginko Jul 15, 2008
    To check voltage a thorough checkout on PSU and pcb boards component must be done.
    This job involves taking apart tv and testing components inside tv. Unless you are quite experienced servicing TVs, the job should be done by an expert.
    I suggest contacting service number that you find at the end of owner manual.
    If you want to DIY, check the voltage coming to the lamp from the pcb board controlling the lamp, you need to use a Multimeter
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Nov 12, 2007 | Samsung DLP HL-P5663W 56" TV
My samsung tv hlr5067wx/xaa screen turns black, sounds is fine. if i turn it off for awhile i can get picture for a few minutes, but it goes back to black screen
I suspect the lamp is failing on your TV. The lamp replacement code is listed on the side of the TV on a sticker that is orange and white. It will start with BP96-. The lamp code is crucial on these older Samsung DLP's because they used quite a few different styles. Please take a few moments to rate my answer. Thank you...
Nov 19, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
My samsung dlp tv sp50l7hx had to bemoved to lay
although the lamp may look ok your tv has all the signs of lamp fail they only need a slight bang. I know that it is cheaper to replace lamp than light engine
Nov 08, 2009 | Samsung SP50L6HX 50" DLP HDTV
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung 50" DLP HDTV keeps humming when the DLP lamp comes on.
Hi, you have one of two problems, either the color wheel is going or one of the cooling fans are going, the color wheels are a very common problem in samsung dlp`s, sorry I can`t nail it to a specific part but I`d bet it`s the color wheel as they are notorious for failing in samsungs, video-tek
Mar 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
