Question about Video Cameras
Canon XL1 Camera won't power up. Power source is good. It was working 2 minutes ago on my Avid. I shut it down, then realized the tape was still in the camera. Now it won't power up for me to eject the tape. Any suggestions?
I paid the premium service but your tech knew less about the camera than I did. He didn't know the Canon XL1 at all. His directions indicated he had no idea how the camera worked.
Posted on Jul 14, 2008
I have a jvc gr-sxm26u camcorder and it has two problems... the tape door will not open when the eject button is pushed to the left. 2nd problem. the screen indicates that there is a problem labeled as "...
E01 Mechanism has not fully loaded up to the stop position
E-01, E-02, E-05, or E-06 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code which is to inform a technician which area of the camcorder to examine in order to ascertain the nature of the problem. Try the following steps:
1) Remove power source for 1 minute. 2) Reattach power source. 3) Try operating the camera.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E- 04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
3) Press "EJECT" (DO NOT PRESS POWER)
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
A common E01 problem with the JVC is caused by electrically conductive residues on the very end of the connector strip which connects the small front circuit panel to the main circuit panel (this residue can only be seen under a microscope). Symptoms are, the mechanism remains closed or the cassette holder will not latch down and remains permanently raised. Basically the micro cannot read the mechanism position data. The connector strip needs to be taken out & carefully cleaned with alcohol.
If all else fails then its a trip to JVC service and a biil of between $`100 and $250 depending on what the problem is. My last E01 was a motor change and cost $180 but the cam has been fine ever since but next cam will be a Canon..
Oct 14, 2009 | JVC GR-SXM260U Camcorder
Auto power off
Link to user manual
No you can't turn off this feature
Nathan Petersen June 17th, 2005, 04:03 PM Is there away to turn the auto power off off. I dont think there is, just thought I'd ask, thanks. Don Palomaki June 17th, 2005, 08:47 PM Not on the original XL1. It will drop into STANDBY from PAUSE if there is a tape in the transport after around 5 minutes. If there is NOT a tape in the camcorder it will not not drop into STANDBY but will remain operating as a camera. Xander Christ June 17th, 2005, 09:25 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true. Don Palomaki June 18th, 2005, 07:33 AM True - in that when using the battery, the camcorder will shut down when the battery runs out of available charge. However, using the A/C adapter does not prevent the XL1 from going into standby if a tape is in the camcorder. Nathan Petersen June 18th, 2005, 04:52 PM Canon suggests that the only way to keep the XI from shutting off is to use the AC adapter as the power source, not the battery. I haven't tried it, so I don't know if it's true.
No it still does it with the AC adapter, Im not even using the battery. It makes no sense to have the auto power off when shooting indoors while using the AC adapter, its just stupid. Don Palomaki June 19th, 2005, 05:59 AM Again, the key point is having a tape in the XL1. After about 5 minuts it goes into Standby mode (not the same as turning the power off with the dial). This is a carryover from pure consumer camcorders - to save battery and reduce damage to tape and head wear from a camcorder left in pause mode for a long time.
Pro users complained, so the XL1s had an option to disable this feature so that only the tape transport (VCR portion) is turned off after 5 minutes, the camera head continues to run. link to above thread
Dec 02, 2007 | Canon Optura Xi Mini DV Digital Camcorder
While trying to capture a DV tape, avid freezes ( rainbow wheel )
Is it dv and not hdv? Have you selected the record format, using a native one is generally best. Take it you are using firewire directly, it could be the camera driver - codec, Can you borrow someone elses and try? Has it worked for you before (with and with-out that camera)?
Jun 11, 2009 | Avid Xpress Pro - (bundle) (05600360101)...
Camera no power
You are right. It is not the battery. XL1s may have a blown transistors in the power PCB. It probably would not damaged any other are but power. This symptom requires a disassembly and removal of power PCB and repair. Sorry, I could not give any quick resolution for this. James. For further assistance, go to www.camerarepairjapan.com
Mar 24, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon xl1 heads
Trained technician can clean the video heads individually and manually but I do not recomend it for general public. Best you can do is to purchase a good head cleaning tape. First, dust off the tape loading area with can air, then run the head cleaning tape for 10 seconds (our general recomendation is 5 seconds) but NO MORE. hope this works. -James. For further assistance by email, go to www.camerarepairjapan.com
Mar 11, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon XL1. Unable to playback tape in camcorder
I have the solution that the canon expert forgot to mention. And this solved my exact problem too. I put in the tape and then shut the white door over top. This doesn't engage the tape. Problem solved. Human error, The fix cost nothing.
Mar 04, 2009 | Canon XL1S Mini DV Digital Camcorder
Canon xl 1s won't power up. Power light flashes, screen lights up then it turns it self off..will keep repeating like this every few seconds but won't stay on help
Just fixed this problem. It is one of the three main fuses that have blown out. This is not supposed to be consumer accessible or fixable, but I did it.
Open up the camera case using the 5 allen head screws disconnect the top ribbon cable going to the playback buttons on the handle. on the main board (behind the tape deck) are 3 tiny square black fuses The top fuse FU3201 is the VTR The middle fuse FU3200 is the Motor The bottom fuse FU3202 is the Camera/Lense
The bottom fuse was my culprit. I found a tiny piece of copper and bent it into a U shape and slipped it over the fuse so that it touched the metal terminals on both sides and bypassed the fuse. This fixed the problem.
Haven't used the camera extensively since, but shoot about 10 hrs a week with 2 xl1's and will post if anything happens.
Here is a diagram from the Canon XL1 Service Manual: http://www.coycypert.net/files/xl1.png
Here is the service manual download link: http://www.coycypert.net/files/CANON%20DM-XL1.pdf
Feb 20, 2009 | Canon XL1S Mini DV Digital Camcorder
We are in the middle of a production (Live, right now) and one of our XL1's is shutting down whenever we hit the record button.
It may be timing out. Is the camera in standby mode? If yes, put it in record and lock.
I have an XL1 and a GL1 that sometimes shuts down. Is there a tape in the camera? It will time out sometimes if there is no tape rolling. Even if I am capturing directly to a computer, I always roll a tape, just to keep the camera from timing out.
What does your battery guage read in the viewfinder? A low battery will shut you down without warning. Try running from the power adapter if you have one.
Dec 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Canon xl2 playback
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Nov 14, 2008 | Canon XL2 Mini DV Digital Camcorder
Hello - Canon ZR80 - auto shut off
If you're trying to use the camera as a webcam, just remove the tape. The auto power-off is a safety for keeping the tape from getting damaged.
Nov 18, 2007 | Canon ZR80 Mini DV Digital Camcorder
Video Cameras Logo
167 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
