Question about Kitchen Ranges
The oven is working but the gas rings on the top of the cooker will not fire, i think tht it is somethng to do with the oven setting controls (which we never use) ared hand comes up and it bleeps. can you hellp?
You will charage me for help so how much do i get if i tell you how i fixed it?
cheers.
m
Posted on Jul 16, 2008
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Touch control not working on aeg d98000 cooker
I'm afraid you have a bad board. I had a neighbor with the same problem and he had to replace just the stove top part. Hopefully, yours is just the temp setting part, but it may not be that if you can control the oven setting.
Feb 24, 2013 | Ovens
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Gas cooker, the oven works but no gas going to rings
you need to check the pipe that take gas in to rings , and check the adjuster button .... where you live may be i can help you
Jan 25, 2010 | Kitchen Ranges
No gas to lower oven - Cannon Camberley
Hey Stephen - try setting the clock then set the cook period. the oven will only work when that's on i think.
May 07, 2009 | Ovens
How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Apr 07, 2009 | Magic Chef 31000 Gas Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
