Question about Olympus FE-230 Digital Camera
Lens not working after only one year
Turn on camera, makes grinding-type noise, then lens goes in and out several times... nothing focuses... when trying to zoom, camera turns itself off. Camera is exactly one year and one month old. Very annoying that a camera only lasts one year. You can bet that I will rate Olympus much lower than I have in the past for reliability when I fill out Consumer Reports' survey this year. ANy solutions found yet?
  • 4 more comments
  • chelseysugar Jul 30, 2008
    Hi there - same problem with my camera - started to make the grinding noises and won't focus etc approximately 1 year after I used it. It's now not covered by the warranty, of course! Looks as though this is more common than I expected.
  • bornlate Sep 20, 2008
    I meant to post this as same problem, not solution, sorry: Same here.. bought the camera early April '07. Problem began in May of '08. Turn it on and the lens goes in and out several times but it won't focus.
  • Anonymous Oct 01, 2008
    I have the same FE230 camera about 1 year old. When powering up the lens moves in and out making grinding noises then finally stays out, the screen is black. I switch the mode switch from auto to movie and back to auto, then screen works but will not focus. When I move the zoom lever in either direction the focus (lense inside) moves all the way in one direction and then the other no in-between. Sorry! I have no ideas I guess I will try to call Olympus.
  • amoeller Dec 04, 2008
    I have had the camera since June '08. It started doing this same thing in November '08...pretty sad. I don't know what even started it.
  • laura Dec 05, 2008
    I bought it for my husband 4 months ago!! :(
    It doesn't focus properly anymore, you never get a clear and neat image. Actually this is the second one. Pretty sad...
    I'll try the shaky shaky thing.. but not happy about the product.
  • waigani74 Dec 07, 2008
    the camera will not auto- focus. it goes dark sometimes. Same problems as others have described
OMG This one was pissing me off for the longes because I love to take pictures and the zoom no longer wored on my camrea and the Lense just stayed poped out and would not retract.
I turned on the camra. and then turned it off but while it was turning off I pressed down on the lens and it snaped back into the camrea like it belonged and now it works like new again.
I turned it back on and was able to zoom in and out just fine and when I turned it off it went right back in like it was supposed to!!!
THANK GOD!!! : )
Posted on Dec 15, 2008
Posted on Sep 20, 2008
  • bornlate Sep 21, 2008
    Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
    Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
I did the same exact thing as foxy p and it worked. If you turn it on, wait for the lens to stay out, then push the on button and put pressure on the lens as it's going back in, it works perfectly the next time you turn it on- no buzzing or blurryness at all. I'm a little wary of how stable it is but hopefully this is a good enough fix for now.
Posted on Jun 04, 2009
Unfortunately, had to send the camera in for repair... around $75... but they replaced the lens among other things, so I suppose it's a brand new camera for $75. Although still agravating that it was only "good" for one year.
AF S Nikkor 18-200mm DX VR lens is 4 years old and making a "motor" or grinding type noise when focusing. Not every time, but it concerns me as it is my main lens and wedding season is...
Yes, I would be concerned about that,,, you probably have some dirt in the lens causing it to turn hard...
Checkout this tip about digital camera error messages
Lens Error fix for Digital Camera
heatman101
May 14, 2011 | Cameras
Auto focus drive not working. Makes a grinding noise and nothing happens. Sounds like a gear has stripped.
First try to use another lens If:
A. It does the same thing, bring your body to a camera repair shop.
B. It doesn't, you'll need to either buy a new lens or repair it at a camera shop.
Apr 20, 2011 | Sony Alpha 230 Digital SLR Digital Camera...
Lens makes grinding noise
yes dust in mechanism or broken gear but ti not easy
Oct 12, 2009 | Panasonic Lumix DMC-FZ5 Digital Camera
Sony 18-70 kit lens vibrates badly
This is a lens problem, the AF motor of the lens is trying to engage the gears. Sometime it works, sometimes it does not... It happened to my sigma 70-300. The only solution is to have it repaired. If under warranty it should be free, if not.... might be cheaper to buy a new lens.
Sep 28, 2009 | Sony A100 Digital SLR & 18-70 Lens Kit...
When I power on, the lens keeps going in and out repeatedly
Turn on camera, makes grinding-type noise, then lens goes in and out several times...try to put your camera in a table lcd side down and turn it on...while lightly tapping on the sides of the lens. also try to check out this link
http://www.olympusamerica.com/cpg_section/cpg_servicerepair_warrantyinfo.asp
Nov 26, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Jammed
Nov 22, 2008 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
I need help with my FE-230's focusing
in any case where the lens makes a grinding noise, something is in the channel and causing the lens to not extend all the way... you will need to send to a repair shop
Jul 31, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital problem
Jul 27, 2008 | Olympus FE-230 Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Olympus FE-230 Digital Camera Logo
207 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
