Changed isp but cant get connected on my dynamode wireless router only on router supplied, isp now talktalk
  • Michael Ortega
    Michael Ortega May 11, 2010
    What's the configuration? ISP is PPPOE, DHCP, STATIC?
    How is the internet interface on the wireless router configured?
    MO
2 problems 1.pressed reset on btm of router
2.password was case sensitive
everything appears to be ok now.
Posted on Jul 13, 2008
Cant connect to the internrt via talktalk modem
This could easily be an issue with either your TalkTalk internet connection or your Wii. I did experience issues connecting my Nintendo Wii console at first too, but after getting a new router, it works just fine.
The Nintendo Wii console has never been a very good internet-enabled console anyway, and alot of wireless settings will not be compatible with it.
Make sure that your TalkTalk router is using WEP or WPA-PSK security. You can also try changing the Wireless Channel and MTU Size. make sure the MTU size is set at 1450, the channel can be anything, but only a few should work. You can access these settings easily by just going to Internet Explorer and typing in:
  1. 192.168.1.1 for D-Link and Huawei
  2. 192.168.0.1 for Netgear
  3. 192.168.1.254 for Thompson Speedtouch
If TalkTalk did supply your router, then it should be one of the models mentioned above.
If you have any laptops or phones that use the wireless and it works fine, then it may just be the Wii console. TalkTalk will not support the Wii or any video game console so there's no point in calling them for support.
I work for TalkTalk as a senior technician, so I hope this information helps.
Take Care.
Feb 20, 2011 | Nintendo Wii Console
Belkin FSD7632-4 v8 wireless router will not connect to my ISP
It should be ok aslong as it is in sync. Can you tell me what router settings your using for talktalk? It should be PPPoA, Vc Mux, Mtu of 1432, Idle of 0. Ip assigned by isp is yes. Also make sure your username and password is correct.The username is going to be
yourphonenumber@talktalk.net and password is as provided by talktalk. IF your getting stable sync on the belkin the distance and noise levels shouldnt be causing an issue.
Apr 16, 2010 | Belkin (F5D7230-4) Router (587009)
When i changed my isp from talktalk to sky broadband my dell 1450 adaptor can not connect even though there is a connection via ethernet cable apparently dell say it is a software problem and want to...
When it says 'Conntected: 100Mbps" on the bottom, all it's saying is that you have a physical connection between your computer and the device it's talking to.
Now one thing you need to double check is that (I assume you have a wireless router) the router or whatever device you have connecting to your ISP modem has the correct network information. For example some ISPs will give you a static IP address that you have to manually add to your router. If TalkTalk does that, and Sky doesn't, make sure your router is automatically obtaining an IP address. This should connect you to your ISP and to the internet. Then your DELL machine should get an IP address from your router and then you should be good to go.
Let me know if you need any further assistance.
Dec 10, 2009 | Dell 1450 (D1450U) Wireless Adapter
Cant access router setup
If you type in http://10.0.0.2 to the adress line on your web browser, you should see a login window for the router. I think it is the wrong address. I think you should first RESET the router. Look for a little hole about the size of a pencil point. Stick a paperclip in and hold it in for about 1 minute. This should reset the router to factory settings.
If you have the manual, it should tell you how to access its setup pages. This is a modem and router in one. You must have an ADSL phone connection to an ISP. You must have the ISP's information to connect to their network. This information is needed to set the modem part of the router to log onto the internet through the ISP. Best of luck.
May 29, 2009 | Dynamode RADSLC4WG Wireless Router...
ZYXEL P-660HW-T1 V2 WIRELESS ROUTER MODEM WILL NOT CONNECT TO MY ISP
is your router connected to your ISP ? (does your dsl led light up ??)
if no! check your wires from phone to router!! and check your SPLITER !!! (i had the same problem, i got bad spliter !!! NEW BUT FAULTY !!!)
chears
Sep 23, 2008 | Zyxel Prestige 660HW Wireless Router...
Problem with wireless router
change your MTU in the router management pages to say 1200, if that works increase the figure to highest level where the pages load, the mtu is preventing secure content from loading - maxium transmission unit.
If that does not fix it then your ssl settings in ie will need to be reset. Download a tool to do that from here http://www.support.talktalk.net/
let me know what solves it!
Jul 09, 2008 | Computers & Internet
Wireless connection
Did you change your wireless SSID and channel? Better to enable encryption too. If this problem never happens when you're connecting to other wireless networks you might as well update or reload the firmware/software of your router.
May 22, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
