Question about Kenmore 20172 Top Load Washer
Kenmore calypso washer
Error code LD on washer. What does this mean?
  • 4 more comments
  • Anonymous Jul 18, 2008
    how do yoou unplug a clogged pump
  • jrbassick Aug 03, 2008
    I start the wash cycle and the LD code comes up...not sure that the problem is..its not overloaded
  • Anonymous Sep 16, 2008
    same as everybody else, I want to start the washer and as I do after about 6 minutes, the LD starts blinking...
  • jowimb Nov 26, 2008
    I get a code L5 when I try to start my washer
    What does that mean, will not start
  • Anonymous Feb 14, 2009
    LD display...
  • pattiqu May 11, 2010
    Is it possible for me to fix this problem? What needs to be done? Please help me out. Thank you!!!
    Master:
  • 505 Answers
Your water pump may be Blocked
Posted on Jul 18, 2008
  • 413 Answers
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Posted on Jul 13, 2008
SOURCE: What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Posted on Sep 02, 2008
SOURCE: Kenmore Calypso washer Ld code?
I recently had the same problem. I actually took the two hoses off of the pump and found a penny in their. It was actually difficult, I couldn't figure out an easy way to get the water out first and had quite a mess. But now the washer works again.
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: what does LD and OB mean on my washer
LD means long drain and will require a pump replacement. The new pump is totally different from the old one so unless you are very crafty and good at figuring out puzzles, you may need to have a service company come out. I don't know what the other code means but most of the time the pump is the major problem with these units.
Posted on Apr 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: What does the Ld code mean on a calypso Kenmore
Hello there
LD means a long drain
it is taking longer than 8 minutes to drain out the tub
please check the following
First unplug the machine to prevent electrical shock·
Check wiring harness to ensure they are all connected and are not fried
·If needed remove the side panel and Check the hoses going to pump for clogs and all drain hoses and drainage system
· Check circuit board that controls the pump to see if any wires are burnt or have failed
once the faulty part or the clog has been cleared simply plug in the machine and press the cancel button and resume your normal washing operation
Hope this has been very helpful for you
Best regards Michael
Posted on Dec 30, 2009
Testimonial: "Thanks for the feedback....the water pump had a sock.....Thanks...."
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Hi
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get LD error/ fault when washing
This error code means long drain.
What this means is that the drain is either clogged or kinked. Please inspect your washers drain hose and than press stop/cancel to clear the code.
Jan 13, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
My calypso is saying ''LD'' I dont know what to do for it.
Ld means long drain. Theres a problem with your pump. The pump for these washers are around 100 bucks. This is a very common with the calypso washers.
Jun 30, 2009 | Kenmore Washing Machines
What does LD and OB mean on my washer
I'm not sure what the codes mean but here is a site that may help with your problem..not sure but do try it if you like..
http://www.repairclinic.com/RepairHelp/RepairHelp.aspx
Apr 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ld and ob error codes
hello.........
“LD” stands for “long drain,” meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I’ve even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the “LD” error code springs forth from such anomalies.
Sep 07, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 20172 Top Load Washer Logo
283 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
