Accidently deleted Paperport, how can I get it back?
    Guru:
  • 1,342 Answers
Look in the Recycle Bin
Posted on Jul 12, 2008
Have an older Visioneer 7100 USB Scanner, Has worked fine for more than 10 years, Now I can't get any scanned objects to appear on my Paperport Desktop. Have no problem using scanner with all other...
Have you upgraded to newer version of windows? Have you tried reinstalling Paperport? (back up max files 1st) I have had a visioneer and still use Paperport 8. Often I have problems with Windows 8 and reinstall paperport now and then.
Mar 07, 2014 | Visioneer Office Equipment & Supplies
Scansoft paperport 11 msi
You must contact Nuance Customer Support for assistance. If you are unable prove/document PaperPort ownership, you will need to purchase the program.
PaperPort Nuance
Feb 07, 2014 | Computers & Internet
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
I use PaperPort 8. When I try to print to PaperPort or PaperPort Color, everything appears to work fine but the item doesn't get to the PaperPort folder. this happened once before and someone at FixYa...
http://www.fixya.com/support/t763517-paperport_selection_printer_but_item
http://nuance.custhelp.com/app/answers/detail/a_id/5852/~/changing-the-default-folder-location-for-paperport
https://support.brother.ca/app/answers/detail/a_id/86451/~/how-do-i-change-the-folder-to-save-scanned-documents-in-paperport-12se%3F
http://paperport.helpmax.net/en/changing-paperport-options/changing-paperport-options/changing-the-default-folder-name-and-color/
May 01, 2017 | Computers & Internet
Scansoft paperport 10 keeps loading every time i switch on
Check the Startup folder in the Start menu. If it is there, simply delete the entry there. Otherwise you can use "msconfig" from the Start Run menu to control the startup programs and disable paperport.
Dec 22, 2009 | ScanSoft PaperPort 10 (1313547SF)
When scanning to ocr I get brccMCtl.exe has encountered .... and it shuts down. I can scan to email, file, and image. But Not to OCR. The Brother Control Center 3.00 is the problem.
I deleted all Brother programmes from by PC, cleaned the registry and used the Brother Uninstall programme first. (I restarted the PC after each deletion)
Then I reinstalled the latest Brother printer driver software without the PaperPort SE 11 programme.
Then I installed the Paperport programme separately.
It worked.
Thanks
Oct 26, 2009 | Brother MFC 490cw Color Inkjet...
I need to change the settings in Paperport 9 so when I hit one touch bottom on the scanner it will save it in a lower resolution so it can be sent via email
To scan directly to email in Jpeg format when pressing a designated button on
the scanner. This may work for other scanner models, Paperport versions, and image formats.
Basically, all that is required is to create a new link in Paperport, enable the format conversion options, then select this link in the OneTouch panel. However, there are a couple of hiccups along the way that may prevent this from working. First, if you choose JPEG as the only format choice for conversion it will not work. For some strange reason you must enable other formats for conversion choices even if just for effect.
Secondly, after creating the new link in PaperPort you may find that the selected icon does not appear in the OneTouch control panel. In order to get it to show you have to refresh the panel by selecting an Icon with the same executable as the one you created and then clicking on the Options button on the lower left hand corner. Once you close the Options window the new link icon is now visible. If you choose to delete a link in Paperport but it has not deleted from the OneTouch control panel, simply do the same thing you had to in order to get it to appear, that is, select another link icon that
has the same executable and click the options button.
Lastly, there another strange quirk that I haven't been able to nail down yet but it seems that sometimes you must wait several seconds for changes to take effect and at other times you must open and close a window a few times for the changes to take effect.
Sep 04, 2009 | ScanSoft PaperPort Deluxe 9...
Paperport 9 deleting problem
Hi
If you find the folder in which the scanned items are - it may be your my pictures or somewhere in your my documents you can delete them from there by clicking and dragging to select them all then pressing 'delete.'
You may also want to try holding down 'Ctrl' and selecting them all then pressing delete.
Hope this helps, good luck!
Philip
Jul 11, 2008 | ScanSoft PaperPort Deluxe 9...
Paperport selection on printer, but item does not print to paperport
Hi Try this solution: Go to your printers and faxes control panel and right mouse on say the paperport colour image printer. Now select the Paperport tab and you will find where the images are being sent! Probably in the bowls of documents and settings; all users bla bla. Change this to where you want them to go. I changed mine to drop into the MyPaperPort Documents folder for ease of use.Do the same for the black and white printer if you like.
Jul 09, 2008 | ScanSoft PaperPort Deluxe 8.0...
Paperport 10.0 deleted by repairman.Lost discs and access to data. Cannot reinstall.program.
my only suggestion is to download and install a trial copy then retrieve your data that may have the serial number for you to register again.
good luck
Terry
Mar 19, 2008 | Computers & Internet
188 people viewed this question
jasbo
jasbo
