Related Tags:
This problem should be removed because:
Problem with AMC Multimedia AV81HTC-DD 6-Channel Amplifier
Marantz 2225
I have a Marantz 2225 which we purchased new in the 70's (I think). Some of the bubls in the tuning display are out and I need to replace them. How do I remove the nobs? I have tried pulling, but that doesn't seem to work. My 78 yr old hands have lost some strength, but I should be able to remove those nobs. I have replaced hard drives, etc in my computer, so this should be doable. Sugestions?
Solutions (2)
My dear Kerrlady:
Para cambiar los focos no es necesario quitar la tapa de enfrente.
En la parte de adentro está la placa que contiene los focos,lo único
que tiene que hacer es quitar los dos tornillos que sujetan esta plaquita.
Lo mismo para los focos de los medidores.
Estos focos son tipo fusible de 8 volts (dificiles de encontrar).
Saludos desde la Cd.de Mexico.
By wrapping a flat blade screwdriver witha towel and gently prying upward I removed the nobs. Now on to the next challenge. Thank you for allowing me to post. The project is not finished. May need other help.
NAD C370; Marantz PM68; Rotel RA1070; Denon...
Can anyone please help me- need to know which of these amps is best (and why)? Thanks heaps Ewan
marantz model 2225
how to replace bulb lights on my reciever?
ev eliminator 1 18 sub
how do you replace a speaker in these cabs without being triple jointed
where is the internal fuse of marantz pm7200
Add Your Solution
How do you change the wurlitzer 3500 belt?
How do you change the wurlitzer 3500 juke box belts?
my amc will play tv through stereo mode,but not...
I am hooked up out of my mitsubishi tv by the digital audio out,and the standard rca out . Could the dolby digital...
Fix-O-Meter
321
321 people viewed this problem
- 0 people are following this problem. Be the first!
Top AMC Multimedia Amplifier and Preamp Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
