My vga turns a green tint and the flashes back to norman and then to green
  • chacmool52 Apr 24, 2009
    I have an HP s3020n Vista 32bit pc. I also have the green tint all over my screen. I tried three different monitors and three differenet cables and the green tint still appears.
    I've been told that since the video card is intergrated with the motherbaord, I will have to replace the entire motherboard.
    Could there be another solution?
    Guru:
  • 1,342 Answers
Check your cables
Posted on Jul 12, 2008
Projector image has heavy green tint, change lamp but still getting green tint, what should I check next?
Check the connection. Some pins on the VGA? may have been twisted or broken. Use a different cable.
Apr 01, 2016 | Office Equipment & Supplies
Green tint - even background when blue selected
We have usually found it to be the VGA cable connection when the whole screen is tinted. Have you checked the pins in the VGA cord as well to make sure one is not missing or bent.
Apr 18, 2014 | Epson EB-X72 diamond lamp
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
Green tint on flash photographs
without color correction software on your pc, you may get green tint from the flouresent flash, or use a "filter" over your lens.More expensive digital cams correct for this, back in the 35mm days, I had color correction filters I interchanged during shooting under other than daylight conditions,i.e., incadescent; flourescent;ect.
Jan 27, 2010 | Moultrie MFH-DGS-100 Digital Camera
Video is taking on a red tint which is getting worse over time
check the cable connections. look at different inputs. VGA and Component cables have the colors split, so if it's turning red, green, or blue; it's likely a cable or connector.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Monitor screen changes from regular color to a green tinted screen?
Looks like you need to purchase a new monitor. If it's too worn out then it's the outcome. I also had the same problem before and I ended up buying a new one. You should not experience that thing if it's new.
May 27, 2009 | Dell 1503FP 15" LCD Monitor
Green tint
what cable are uusing coumpount vga 15 pin to coumpunt or u try new cables
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Infocus LP70 - It's all Green
A tinted image (whether green or another color) is almost always a symptom of a bad or damaged cable - or a loos cable connection. In your case, you'll likely need a new M1 to VGA cable (Part# SP-DVI-A-R).
Assuming that you've made sure that the cable connections are solid at both ends, there is a simple test to verify that this is a cable issue and not a costly projector issue. While the image is tinted green, open the menu. If the menu colors appear fine while the rest of the image is still tinted green it's the cable.
Nov 20, 2007 | InFocus LP70+ Multimedia Projector
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
