Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi wt-42311 convergence issues
So i found a nice mitsubishi 1080i hdtv just sitting at my local crt disposal facility, and decided to take it home to see if it still got power. lo and behold it did. only problem is all the colors are out of phase. i tried the convergence menu and moved the colors around. my only problem is when i get one part of the screen lined up another part of the screen is out of phase. since i got it free, i am not adverse spending money to get it fixed, but i would like to fix it myself if i can. any suggestions?
ps my dad says it has something to do with the alignment of the RGB guns.
  • DrJaul Jul 13, 2008
    i dont know hat that means. could you please elaborate?
  • 52 Answers
Replace convergence IC's. There are two IC's that start with STK.
Posted on Jul 12, 2008
  • pinoy_eagle Jul 13, 2008
    Your TV has a problem in convergence board. There are to integrated circuits(IC) on this board. And they are needed to be replaced. These are two big IC's and the part number starts with STK. If you are good in soldering, maybe you can do it.
Sizing screen on wt 42311
A problem in HD BUT not on standard 480 programs-----Convergence not good in HD OR WHAT?
Mar 23, 2012 | Mitsubishi WT-42311 42" Rear Projection...
Red shadows
Most likely it is a convergence issue. Have u tried to converge red and Blue?
Mar 18, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
WT 42311 won't power up
All that is wrong is the Convergence IS's. They are located on the deflection board (IC8C01 and IC8C02) and are mounted to a very large heat sink. They are black and are STK IC's, STK392-110. Replace both IC's with STK392-120 and you're in business. The -120's are and upgrade and have a higher amp rating. The IC's can be found anywhere on the internet for $9.99 and up. Check Electronix.com, MCM Electonics, Mat Electeonics for starters. Gook luck. Gary D.
Aug 11, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Red convergence out of range.
Replace STK393-570 convergence IC. located on center PCB.
re-check alignment........T.
Oct 24, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi tv wt-42311
convergance ic bad
Oct 22, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
121 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
