Question about EliteGroup P4M800-M7 Motherboard
System won?t recognize SATA drive
I have an Elitegroup P4M800-M7 mother board and I just bought a new Seagate 750 Gbyte SATA drive. The motherboard does not recognize the drive, I am wondering if this drive is too big. Any suggestions?
  • gurukiransn Jul 23, 2008
    i have a 360gb sata drive it is not supporting
    mail id: gurukiransn@yahoo.co.in
  • clueless77 Jan 11, 2009
    apologies.. I am totally unsavvy.
    I just bought a new Seagate 1T Sata2 internal hard disk but I can't locate the power and data cables on the motherboard P4M800-m7.
    Does the motherboard come with the cables or I need to buy additional?
    Can anyone help?
    President:
  • 2,351 Answers
No, the size does not matter. When you state the motherboard does not see the SATA drive are you saying the bios does not list the SATA drive? You're 750GB drive is most likely SATA 2.0 / 3.00BG transfer rate.
The P4M800-M7 does support SATA but it does not support SATA 2.0. So what you need to do to get the drive to function at a lower speed. Set to run Ultra 100/133MHz. You'll need help to do this. Try this software for Seagate. It might work for Seagate.
http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=126&orderNum=2
I haven't the time to research Seagates site for simular software.
However you can look through Seagate. Again you want to lower the SATA drive speed to Ultra. The bios will than see the SATA & so will windows.
http://www.seagate.com/www/en-us/support/downloads/seatools
Good Luck!
Mike
Posted on Jul 12, 2008
Hdd support for p4m800
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=531&CategoryID=1&MenuID=16&LanID=9
Here is the other version (3.1)
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=548&CategoryID=1&MenuID=16&LanID=9
Your mainboard supports P-IDE and SATA drives.
A large ide drive, is hard to find, but a sata drive does
come up to 3 tb.
But it depends what windows system you have.
Windows xp, supports up to 2 tb, with the latest service pack installed.
Good luck
Feb 15, 2013 | EliteGroup P4M800-M7 Motherboard
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
Sir, I'm using P4M800-M7 motherboard, my cpu totally down only the power light indicator is on...what should i do?
One bad lead will cause your computer to shut down or continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Oct 27, 2010 | EliteGroup P4M800-M7 Motherboard
My elitegroup p4m800-m7 mother goes on but it doesn't boot,it just gives 3 deeps
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 24, 2010 | EliteGroup P4M800-M7 Motherboard
I need some help...A friends laptop is very messed up, i need to install his SATA Hard drive on my computer. I have a SATA Hookup on it, its all hooked up, but WindowsXP is not recognizing it. My brother...
Hi
Thank you for your query
From what you are describing you are missing the SATA controller
Please do the following
1) Go to www.devicedoctor.com and download and install application
2) Once installed load up and click on begin scan
3) Once it has scanned it will probably pick up missing SATA controller and give you the option to download
4) Download the SATA controller and install
5) Reboot PC and the SATA drive should be recognised
Mar 12, 2010 | EliteGroup P4M800-M7 Motherboard
Sata drive on p4m800-7a motherboard
This is not like a question if you have a question don't be fool and don't put like this question.
"Hello" is not a question.
Feb 27, 2010 | EliteGroup P4M800-M7 Motherboard
I need P4M800-M7 mother board driver
go to intel web page and type in your product in the search bar and you should be able to find your drivers.
Feb 24, 2010 | EliteGroup P4M800-M7 Motherboard
System won't recognize SATA drive
Seagate shows you're did not come with a jumper.
http://www.seagate.com/ww/v/index.jsp?vgnextoid=63557ea70fafd010VgnVCM100000dd04090aRCRD&locale=en-US
Try removing the jumper. Check if bios see's the drive. Most motherboards that do not support SATAII will automatically reduce the drive/split the SATAII down to 150MB's. If you had or have another SATA & the bios saw or see's the SATA than it's not the motherboard's SATA controller. Take some time & go through Seagate's trouble shooter site.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=serial_ata_troubleshooter&vgnextoid=85a34a3cdde5c010VgnVCM100000dd04090aRCRD
If the bios did find another SATA other than the ST3750640AS-RK than it's possible the drive has an issue & may need to be exchanged.
Lets hope it's the drive & not the motherboard controller.
Mike
Jul 14, 2008 | EliteGroup P4M800-M7 Motherboard
P4M800-M7
please give me a software copy of motherboard P4 M 800 -M7 A ver 7.1
Jul 13, 2008 | EliteGroup P4M800-M7 Motherboard
Help!!
go to this site and download the manual,it will show you what you need to do.
http://www.nodevice.com/driver/P4M800-M7/get34672.html
good luck
Terry
Mar 17, 2008 | EliteGroup P4M800-M7 Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
2,083 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
