WE are unable to fix the convergence adjustment on our Hitachi 42" HDTV using the remote. How else can we fix this
  • 52 Answers
Convergence ic's need to be replaced. If you are good in soldering, maybe you can do it. Part # starts STK.
Posted on Jul 12, 2008
What is the procedure to do color convergence on a hitachi 50vs69a
Almost all you can either get into the mode by use of the remote or remove front speaker grill and inspection plate behind it, there is a tiny blue push switch which will put you in the convergence adjustment mode, then various buttons on the remote do different things and save the adjustments.
Of course if convergence will not adjust you have a bad chip and this model uses two so both get replaced in that case.
Aug 27, 2012 | Hitachi 50VS69 50" Projection HDTV
The red is wavy and doesn't line up
Sounds like you are trying to adjust convergence through the menu setting on your TV. Make sure you are using that TV's original remote to make these adjustments. If you are unable to make these adjustments then typically it is because one or both of your TV's convergence chips are burnt and need to be replaced. You can find these chips fairly easily but make sure you are purchasing OEM chips made by Sanyo. Sanyo made the majority of the convergence chips for most major brand rear projection TV's. You can find good quality chips at convergencechips.com. Hope this helps,James
Feb 15, 2012 | Hitachi 57F500 57" Rear Projection...
It has a highly distorted picture. The picture doubles up and is concave with "rainbowing". Is this an easy, cheap fix.
you may try to adjust the convergence using your remote it has one, if your HDTV has no convergence adjustment, the convergence electronics circuit inside the cabinet may need servicing or replacement.
Feb 09, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Unable to enter convergence menu
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 08, 2009 | Toshiba 42H82 42" Rear Projection...
Can an amature replace a convergence board?
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Here are some of the most common symptoms of a convergence problem.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Jan 24, 2009 | Hitachi 46F510 46" Projection HDTV
Blurred picture on my 61" HD Hitachi
Sounds like a convergence promblem.
Screen looks 3D
Jan 23, 2009 | Hitachi 46F510 46" Projection HDTV
Weird warped lines
Try the Magic Focus option on the menu.
Jan 19, 2009 | Hitachi 57F500 57" Rear Projection...
My Hitachi 43" HDTV shows double vision with shadows on people and words> I have tried to adjust everything with the remote but that does not work. Maybe there is a remote feature to fix this that I dont...
Is it a rear projection tv? if it is, then the problem is the convergence board. convergence ic need to be replaced. and this can be done by an experienced technician or if you are good in soldering, you can do it yourself.
Jun 06, 2008 | Hitachi 46F510 46" Projection HDTV
Sony tv
Needs convergence IC's replaced....
Oct 27, 2007 | Sony KP-46WT500 46" Rear Projection...
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Try to adjust the red and then the blue convergence.
They have put together a kit for the Hitachi TV sets.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
