Question about RCA Audio Players & Recorders
RCA stav-3990 audio/video receiver screen says powering off as soon as i press the power button, then automatically shuts itself off.
mlapres
  • 757 Answers
SOURCE: No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
Posted on May 08, 2009
  • 336 Answers
SOURCE: ''Power off ''flashes ten times after the receiver is turned on.
Most often it will require an output IC, but I have seen it be a bad ground or a transistor in the protect circuit.
Posted on Oct 16, 2009
  • 336 Answers
SOURCE: i need a replacement remote for a optimus
Optimus was sold only by Radio Shack. It would be a special order. Get the catalog # from the rear of the receiver (31-XXXX)
Posted on Dec 11, 2009
paul4265
  • 592 Answers
SOURCE: I HAVE A OPTIMUS STAV-3770
Hi, Bennie.
I am going to take a try at helping you out with this today.
First, make sure that the DVD player works.
Attach it up to another tv, and make sure you get both audio and video.
If you do, then we go on to the next part.
If not, then the player has the problem.
Let's say that it works on the other tv, ok?
So, if that is the case, then it may be something as simple as having the input settings wrong on your receiver.
Sometimes, this can be from static discharge, other times bad cables.
Also, make sure that tape monitor 2 is not turned on, if it is you won't get anything out of your receiver unless the sound is run through the tape 2 jacks.
There also may be a burnt out fuse, or connection inside your old receiver that has gone and bit the dust.
After all, the receiver model you list was originally made in 1999, so it is well past life expectancy for it.
I know this may or may not be what you were wanting to know, but I tried.
I hope that it does help you in some way, and good luck.
Posted on Mar 14, 2011
  • 5218 Answers
SOURCE: Need owners manual for RCA
The manual and several tutorials are available from Radio Shack: http://support.radioshack.com/support_audio/65131.htm . The direct link for the Owner's Manual (as a pdf) is http://support.radioshack.com/support_audio/doc66/66201.pdf .
I hope this helps.
Posted on Apr 06, 2011
Why wont the power come on? While the red stand by light is on.
Could be an open internal fuse or power supply failure
Dec 02, 2016 | RCA Audio Players & Recorders
Se apaga el rca stav-3970 audio video receiver automaticamente al encenderlo
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 29, 2016 | Televison & Video
I have had this system for 8 yrs now When the Receiver is turned on after 7 seconds the system protection comes on and powers itself off. I realize there is a module inside that is going out. Does an
An output transistor has shorted and is drawing too much current. It's fixable, but use a matched pair of output transistors instead of just changing the bad one.
Dec 04, 2014 | Audio Players & Recorders
Why is my RCA STAV-3860 not coming on?
It sounds like the unit is getting power but is going into standby mode due to an internal fault. Sadly, newer receivers these days are not designed to be repaired but replaced!
Jun 13, 2014 | RCA Radioshack 31-5003 Stav-3860 60-watt...
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
RCA STAV 3990 Power comes on but relay will not
Hi,your amp is going into protection mode.You need to have the amp module repaired or replaced
Nov 03, 2013 | Audio Players & Recorders
I just got a RCA STAV-3990 Stereo/Audio Receiver given to me. I see I can hook up my turntable into the AUX inputs in the back, but where do I put the grounding wire for the record player? My old stereo...
Use one of the screws that hold the receiver's case. Also, if you haven't already tried to use the turntable, make sure that the receiver's volume is turned way down, typically phono inputs are a lot more attenuated than aux inputs are. You may damage your speakers and or your ears!
Oct 07, 2013 | Audio Players & Recorders
Need owners manual for RCA Pro./Series Audio/Video Receiver STAV-3990
I hope this helps.
Apr 06, 2011 | RCA Lands Phones
399 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
