Question about BenQ MP610 Multimedia Projector
New lamp, half screen is bright the other half is much darker
Bright on the left about half way across then the right side is much darker, I can still see images just darker. Even with the guide screen so it must be the new lamp?
  • 1 more comment
  • v8sho Jul 12, 2008
    Already unplugged and replugged it back in... No help
    Is the bulb bad when this happens? $249.00?
    So you thinks it's the bulb when you get half bright other half not so bright?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Hello there,
No, the bulb is NOT to blame for this issue. I know this problem all too well so my answer may be what you (and others) are looking for in the following thread: http://www.fixya.com/support/t25268267-get_rid_dark_shadow_across_top_screen
Basically what happens is a prism in the projector has become dislodged due to the cheap adhesive they use and the extreme heat it's subjected to. Some JB-Weld Steel Reinforced Epoxy will fix it right up. Just read my instructions in the above link.
Posted on May 30, 2017
  • 13,433 Answers
There should be somekind of warranty on the lamp you have pruchased, contact them for another one. as far as I know Lamp and bulb are the same thing.
Posted on Jul 12, 2008
  • Ekse Jul 12, 2008
    fauly lamp / bulb or dirty / dusty internals which is causein half of the screen to be dim. id say the projection itself is just fine the light is not coming over equally?
    Genius:
  • 3,422 Answers
HI,
Please replace the bulb..
  • 4,472 Answers
If you can afford it I would buy another lamp and return that one. How long have you had the unit? Did this happen right away after installing the new bulb?
Thanks,
Lee
  • Lee A.
    Lee A. Jul 12, 2008
    If you can't buy one right away then you will have to wait for the return process from whoever you purchased the bulb from.
    Thanks,
    Lee
  • 1,879 Answers
Greetings,
Correct, if you know how to, try re-connecting the lamp.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
My JVC HD56 has a purple/green tint and isn't very bright.
Not worth attempting to fix and that is the reason it was tossed.
Apr 01, 2012 | JVC HD-56FN97 56" Television
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Right side will not work light glow only
If you have a service vehicle soon light (not service engine soon) this usually indicates a problem with the foreward lamp system.Your problem seems confusing, but check your high beam lamp operation. These cars are NOTORIOUS for corroded harnesses to the headlights. The problem is usually buried behind the washer bottle or across the radiator area. If you are lucky, it may be a burned out high beam bulb. If the blue symbol for brights stays on and there is no click when pulling on high beam lever, you will need a new turn signal switch.
Jun 21, 2009 | 2004 Chevrolet Cavalier
Dlp tv hl-r5688w samsung
i believe the buld is bad replace it its cost from 200 to 500 dollars depending on the year and model
Jun 20, 2008 | Samsung Televison & Video
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Grey line horizontally across screen
yOU ARE HAVING A PROBLEM IN HORIZONTAL CIRCUIT OR IN YOUR POWER SUPPLY kindlyu take your T.V tO A QUALIFIED TECH to repair it.ypur problem could be a faulty capacitor ,flyback or horizontal output transistor.
Feb 16, 2007 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
BenQ MP610 Multimedia Projector Logo
434 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
