I have an 80s model peavy tko 65 bass amplifier. there is some kind of short, the comp. light comes on and it just buzzes... just happened *** i was playing the other day, slapped it and it went away. came back and all i get is a buzz/hum. when i press on the front amplifier face anywhere the green comp. light goes off and it works fine.. when i release pressure it buzzes again. I took speaker out, inserted a different one, same thing, so that rules out the speaker... pulled the amp out and checked the fuse, it was fine... saw no loose solders anywhere.. what could this be?
You have a bad pot.
Posted on Jan 28, 2010
Peavey tko parts
Explain or send a picture, please.
Feb 14, 2014 | Audio Players & Recorders
Loud buzz
Check out main smoothing caps
Jan 02, 2014 | Peavey Audio Players & Recorders
What color speaker wire is positive and negative
Im pretty sure blue is positive yellow is negative. Look on the sides of the wires one of them should have little tiny pluses on them.
Aug 25, 2012 | Peavey TKO 115 Bass Amplifier
My kids broke my gain pod and my eq on my peavy tko 115 where can i get the replacement parts from and what is the discription numbers.
Best to get these from Peavey.
Contact the parts dept by email at:
parts@peavey.com
Be sure to give your model and serial number and the exact name of the front panel controls that are damaged.
Nov 12, 2009 | Peavey Music
No bass coming out
u probably have to replace the rca inputs on the amp or resolder the short on them if u can
Aug 31, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Comp light stays on all the time, like the amp is overloaded. but i have the speaker disconnected, and all the levels turned all the way down. its a peavey tko 65 bass amp
"Comp" usually stands for compression. If the amp works OK but light is on, there is a problem in the compression circuit.
Paul
Apr 10, 2009 | Audio Players & Recorders
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
57 people viewed this question
 Grubhead
Grubhead
