Question about HP PSC 1610 All-In-One InkJet Printer
Copier the roller is making noise acts like there is a paper jam paper won't go any farther, & will not make any copies with the copier.
  • dmh0224 Aug 03, 2008
  • Anonymous Aug 06, 2008
    Has always made noise, but keep saying out of paper, paper jam , there is no paper in the printer jamed but keeps saying this over and over. My husband was talking to someone at work who he hardly knows and they explained exactly what this printer was doing coincidence I think not this has always been a crappy printer they should recall them!
Found the answer here
Posted on Sep 26, 2008
Copier will not copy feed paper oeven try-justs makes agrinding noise
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
Paper won't feed and light continues to blink. hp deskjet 1000 Acts like either there is no paper or it takes it and it binds up in the printer and jams.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Mar 25, 2011 | HP Office Equipment & Supplies
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Ricoh CL 7100 fuser jam.
The grinding noise is the clashing of gears. The fuser is composed of 2 rollers, a metal or ceramic with a heater inside (bulb) and a silicon roller to apply pressure. The 'hot' roller is geared and the silicon roller can be geared or free floating. There is at least 1 paper sensor in the the fuser to let the unit know whether paper is there and there when it should or should not be. Sometimes, the sensor gets slightly dislodged and can actually cause a jam. If you are hearing a gear clash, the paper is being pushed through the machine and instead of being pushed through the fuser, it stops because the fuser rollers are not turning. The rest of the machine keeps pushing, crinkling the paper.
If there is crinkling, then gears that drive the fuser need to be checked. It is this gear cluster and/or the fuser that need to be replaced.
Aug 03, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Pc920 won't make copies
the noise could be the heat rollers have squared of this happens if the machine hasnt been used for a while the pressure makes a flat on the soft roller.. it cold also be the toner cartridge has settled. take it out and give it a good shake.. if you cansee if the scanner lamp and carriadge is moving when you run the copier up it mighht be saveable.. make sure the paper is new and dry as this can cause jams in hot section.. if you can see where the paper jam is when you do one copy check the guides as well and finally take the paper tray out and look at the condition of the rollers that feed the paper as they may be dirty and sliping the paper..Good Luck A
Jul 30, 2009 | Canon PC-920 Black and White Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Orange roller
hi im jules_09,is it all the fuser area?to be safe try cleaning it first with alcohol,if the that doesnot work try metal polish,just be sure its not the opc drum that make the copies ok,get a fine and soft cloth so you would not damage the roller,urb a right amount of metal polish to it then then rub it with cloth gently in one direction the best directio is carefull not to scracth it or the drum
Nov 08, 2007 | Kodak Ektaprint 95 Copier
Paper Jams on letter tray
The paper pickup rollers are dirty and needs cleaning. take out trays and give it a wipe with damp cloth, if problem remains than need to replace the rollers
Oct 12, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
HP PSC 1610 All-In-One InkJet Printer Logo
81 people viewed this question
Ben Johnson
