Question about Bissell Vacuums
No water sprays out when you squeeze trigger - Bissell Vacuums
  • 5 Answers
Generally this is because you didnt clean out the machine & so detergent dries in the jets & blocks them. Take apart clean & hey presto. next time rinse thoroughly when you finish & if you lend it someone dont believe they have rinsed it properly.
Posted on Oct 31, 2010
Water won't spray when I squeeze the trigger. How do I get it to spray the solution?
Hello, this is Ava with Think Crucial.
There are a number of reasons why your unit doesn't spray water. It could be that the !) water tank is empty which you can fill heavy duty bladder with hot tap water. 2) If Formula tank is empty, you can fill it with Bissell 2x formula for cleaning. 3) If tank may not be seated properly, turn the power off, remove and reseat the tank. 4) If pump may have lost prime, try to turn off and then turn on the unit, wait for one minute and depress trigger. If still nothing happens, I suggest you contact Bissell 1-800-237-7691 for further assistance.
I would like to let you know that you can order replacement parts for your vacuum needs. Please visit our website
http://www.thinkcrucial.com/search?type=product&q=bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
Why doesn't the spray trigger release any cleaning solution when it is squeezed?
The water pump is most likely burned out and needs to be replaced. Carpet machines are notorious for broken water pumps.
Mar 07, 2016 | Vacuums
Hoover troubleshooting
Hi! Try these quick and easy steps to get the water from your hose to spray.
Assemble the hose to the unit.
While holding the hose at an angle towards the ground, pump the trigger about 30 times. Turn the cleaner on then squeeze the trigger for 30 seconds.
If the water is still not dispensing there may be soap residue bulid-up clogging the nozzle/valve. Try soaking the trigger end in warm water for a couple hours, then repeating the steps above.
If the cleaner is still not dispensing from the hose but dispenses from the unit, a replacement hose may be needed. Follow the link below to order a replacement hose for your cleaner. Search Results
Aug 23, 2014 | Hoover F5826-900 SteamVac Upright Wet...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
I CANT GET MY BISSELL SPOTLIFTER MODEL 1716 TO SPRAY THE SOLUTION.
1) Make sure there is water in the solution tank.
2) Try priming the machine by instructing the consumer to squeeze the trigger
repeatedly for 1 to 2 full minutes. Important: If you cannot
squeeze the trigger all the way in, remove the tank from the back of the
machine and then try squeezing the trigger with the tank removed. There is an
internal valve that could be sticking. By removing the solution tank and squeezing
the trigger, it should break it loose, allowing the trigger to be fully depressed.
3) Make sure the open end of the siphon tube in the solution tank is not pushed into the
side of the tank, covering the end of tube. If it is, push the bend in the
Siphon tube toward the back of the solution tank.
4) Check to see if the siphon tube has become disconnected from the outlet fitting on
the inside of the solution tank. If so, you need to buy a replacement solution tank. Parts
can be found at www.bissell.com
5) Check to see if air comes through the spray tip by repeatedly squeezing the trigger
with solution tank off the unit. If not, spray tip may be clogged. Try and unclog
spray tip with a pin or paper clip.
If still no spray, please check the following:
a) Make sure the solution tank is installed properly.
b) Check to see if black O-ring is present on rear connector to solution tank.
May 28, 2011 | Bissell 1716 Spot Lifter PowerBrush...
Will not let any water out when i squeeze the water trigger.
Try squeezing the trigger a few times repeatdly. This usually works for me.
Mar 21, 2010 | Bissell Powersteamer 1694 Upright Vacuum
My bissell will spray out of the hose, but no water or soap when i squeeze the trigger? The belt is turning the pump
See if your tank is seating properly. I bet it's sitting up a bit. Is there water in the little well where it sets?
Jan 10, 2010 | Bissell 1699 ProHeat Clear View Upright...
Hoover steamvac won't spray water on carpet.
Check the ank valve to make sure when you push it in that water is coming out. The reservior asm, (the tank bottom sits on this)is bad or the rod in the handle isn't pushing the reservior asm when you squeeze the trigger.
May 15, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
F7425-900 hoover steam vac
There is a valve at the bottom of the tank, push it in and see if it goes in and out ok. The tank sits on the reservior asm., a rod in the handle pushes it when you squeeze the trigger. You may have a problem with the rod not releasing or a bad reservior asm.
Apr 26, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover Steam Vac with Rinse
The bottom tank is for the dirty water, the top tank, it has a small tank attached to it for the shampoo, clear hot water goes in the bigger tank. Then turn it on, squeeze the trigger as you pull it backwards. It will spray and vacuum up at about the same time.
Mar 05, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
124 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
