SOURCE: Gateway Intel 850 Motherboard will not boot
Please download a memory (RAM) testing program for free. Click the link. http://www.memtest.org/
This program will allow you to make either a bootable floppy disk or a bootable CD. Before you can use the above program I will need the correct model No# for the Gateway, found on a sticker somewhere in the PC case along with the serial number.
The information regarding you're board is incorrect. You can find the boards model number written in white lettering somewhere on the board or on the side of a PCI slot.
The link for the Intel 850 is listed here.
http://www.intel.com/design/chipsets/850/
Gatway's link here.
http://support.gateway.com/support/drivers/dlcenter.asp
I'll check back from time to time & check if you have found the correct information.
Good Luck
Mike
SOURCE: Gateway M-6823 Notebook memory
The only reason for this is your laptop only support up to 1 GIG of RAM or 2 pieces of 512 RAM you can check this link for that specs of this laptop http://support.gateway.com/s/Mobile/2007/Tempest/1014768R/1014768Rsp4.shtml
Hope that helps............
SOURCE: Adding Memory to Gateway 420r
If you mean a Gateway 420GR (there's no "420R" listed on their site), then you can have up to 4GB of RAM and you can use 1GB modules. Here's a link to the specs page on their site:
http://support.gateway.com/s/PC/R/4053/4053sp3.shtml
SOURCE: gateway mx6447 wont power up at all
Basic rules say check the fuse in the olug, is it still woking. 2 is check the lead with Multimeter or Voltmeter, 3 is check the battery. I wont go further.
