Question about BenQ MP610 Multimedia Projector
Half the screen is bright while the other half is much darker.
New lamp installed now I have this issue.
  • v8sho Jul 13, 2008
    I just put the old lamp back in and I have the same issue. Saw a disc just to the left of the lamp, anyone know what it is? could I have moved it when changing the lamp? When I'm on a white background I can see the actual line and I see some spots that don't move on my screen. Could I have moved something??
    Problem Solver:
New lamp
Posted on Jul 13, 2008
I have an LG 50LN5600-UI. The left half of my screen is now darker than the right any idea what the problem maybe?
It could be that the lamp is burned out on that side. Close up-, Shine a flashlight into it and if you see an image form it's simply the lamp. If not, then it could be a processor issue or something more complicated.
Jul 11, 2016 | LG Televison & Video
New lamp, half screen is bright the other half is much darker
Greetings,
Correct, if you know how to, try re-connecting the lamp.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 12, 2008 | BenQ MP610 Multimedia Projector
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
Jan 04, 2014 | LG Flatron Computers & Internet
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Asus AL2216W top half screen got darker. Lamp problem ?
When the lamps are bad, the screen will shut down if the inverter cricuits is sensing open (lamps will not fire up and conduct, or lamps are drawing too much current). You should open it up and inspect the caps in the power supply first, lamps in this monitor are ntoeasy to replace (screnn will to be complete,ey disassembled.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 24, 2010 | Acer AL2216WBD LCD Monitor
One half of the screen is darker than the other
Replaced the main tuner signal board.If replaced that if same problem.Than Ur LCD Screen is dead ur CEFO floscent lamps half of is almost dead.
Jan 15, 2010 | LG 37LG30 37 in. LCD HDTV
Upper half of screen is darker than the lower half
Its back light in LCD Panel problem, there are approx 20 CCFLs in 40" lcd panel and one or two in upper half is not providing enough light to give proper brightness so you see bit darker image.
As per Sony policy, lcd panel will be replaced to fix this issue and local tech can fix it on component level (replacing bad ccfl) if he/she agrees because its risky work.
Hope this nfo will help you.
Dec 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Darker screen after replacing a samsung dlp lamp
DID YOU USE THE FOLLOWING LAMP
BP96-00826A (PHILIPS WRITTEN ON THE LAMP)? ALSO PLEASE CHECK THAT THE LAMP IS COMPLETELY SEATED OR IT WILL RESULT IN BRIGHTNESS ISSUES. THERE WAS ONE THAT I REPLACED THE LAMP IN AND I NOTICED THAT THE DIAL OPENING ON THE LAMP HOUSING WAS A BIT SMALL AND WOULD NOT ALLOW THE COMPLETE SEATING OF THE LAMP AND I HAD A DARK PICTURE AS A RESULT. I USED MY CORDLESS DRILL WITH THE PHILIPS HEAD STILL ATTACHED AND REAMED THE HOLE LARGER AND IT SOLVED THE PROBLEM.
HOPE THIS HELPS.
Jul 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Screen is half dark and whistles when battery is unplugged
You could have a defective screen, either a faulty inverteror a CCFL lamp - follow this to determine the fault.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Dell Inspiron 1521 Laptop
BenQ MP610 Multimedia Projector Logo
202 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
