Question about Maytag Kitchen Ranges
Maytag Range 8yrs old model MER5770ACW after cleaning cycle completed control clock dead except word "off" when a button is pressed shows
Hold cancel and stop/time button together for 3 secs. Found causal and solution in servci3e manula that i found online.
Posted on Jul 13, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
How can I get self clean to start?
To Self-Clean Using AUTO-CLEAN
1. Press AUTO CLEAN.
2. Press the HOUR and MIN "up" or "down" arrow pads to set the desired self-clean cycle time.
3. Press START. The oven door will automatically lock. "CLn," "LOCKED," "ON," "CLEAN," the Cooktop Lockout icon, and the time remaining will be displayed.
4. When the self-clean cycle is complete "END" will be displayed, and "PUSH"/"OFF" will blink alternately.
5. Press OFF/CANCEL. "LOCKED," "END," and the Cooktop Lockout icon will disappear from the display. "PUSH"/"OFF" will stop blinking, and clock will show the time of day.
6. Once the oven is completely cooled, remove ash with a damp cloth.
I hope this helps and thank you for a model number that made this possible for me to assist you. Good Luck
Apr 05, 2016 | Whirlpool GS563LXSS - stainless Steel Gas...
FGGS3045
Good Morning Ralph,
I understand that you were running the self-clean cycle on your Frigidaire range, model# FGGS3045, and it stopped and the control panel went dark. I also understand that there are no lights of any kind. I suggest that you give your appliance a hard reset by shutting the power off at your home's circuit breaker for 3-5 minutes. Once time has passed, restore power to your oven.
If you do receive power and the control panel and lights come on, you will have to reset the clock before doing anything else. You will reset the clock by pressing the "Set Clock" button. "CLO" will appear in the display area. You will then enter in the time and press the "Start" button. "CLO" will disappear and the time will show. Once you have reset the clock, try either turning your oven on a bake cycle or the self-clean cycle. If the same thing happens, to where the control panel goes dark and the lights go out, I suggest contacting your local authorized technician.
If you do not receive power, I suggest contacting your local authorized technician for assistance. They will be able to diagnose your range and determine why there are no lights coming on, as well as no power to the control panel, and if there is a temperature cutoff that might possibly be causing your range to not have power. Hope this is helpful.
-Best Regards-
WP
Mar 08, 2014 | Frigidaire 30" Slide-In Gas Range FGGS3045
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
STOVE STUCK ON SELF CLEANING CYCLE
Try pushing all buttons several times each to unstick a stuck panel button. If that does not work the ERC clock control will have to be replaced.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Dec 12, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Maytag electric range buzzes and resets clock when key is pressed
the membrain has a almost stuck key / if the clock has w warped face . then some of the buttons are almost closed. asn causing some problems . it won't get better in time if will fail . and the clock will have to be replaced . .. mm hope this helped .
Dec 12, 2009 | Dishwashers
How do I set the clock on a Maytag gas range, I
If your range is the same model as you posted this question under, the time is set by pressing the "CLOCK" button. The word "TIME" will begin to flash on the display. Using the keypad, press the corresponding numbers of the current time.
NOTE: If the oven has been programmed, or is in use, you cannot change the time. Cancel all other functions before attempting to set the clock.
If the model number is not correct, please post back with your correct information so that I may be able to provide you with better assistance.
Nov 01, 2009 | Maytag MER6772 Gemini Electric Kitchen...
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Oven display won't work
rmedrano, Try pressing and holding the stop-time and cancel pads together for 5 seconds, see if it comes back to life. If not, try the cancel and clock keypads together for 3 seconds. First is the control lock-out funtion and the second is the display blank mode. If these fail to work, you are going to have to test for power at the board. The clock (ERC) has a 3 year warranty incase you have to call for service. Catriver.post back.
Dec 16, 2006 | Maytag MES5770 Electric Kitchen Range
Kitchen Ranges Logo
132 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
