Question about Dryers
Hotpoint condenser dryer making loud continuous noise whilst spinning
  • Anonymous Mar 13, 2014
    drys clothes but is making a loud noise whilst spinning - why?
    Scholar:
  • 170 Answers
Pull the front panel off and check the roller wheels that the drum rides on. These have bearings in them that will eventually go bad and start to make a racket. They can be easily replaced and are usually sold at appliance parts stores in pairs.
Posted on Jul 12, 2008
Why is my hotpoint upright freezer making a loud pulsating noise?
Check to see if the condenser coil needs to be cleaned. And make sure the condenser fan is running
Always disconnect power before attempting to repair any electrical appliance
Oct 15, 2017 | Hotpoint Freezers
Clunking banging noise
It may be something stuck in the drum, ie a bra wire, which would have extra weight on it whilst the clothes are wet. If this is the case, it will need looking at sooner, rather than later, as it will just be causing further internal damage
Dec 19, 2013 | Fisher and Paykel Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Loud squeaking noise hotpiont dryer
either the remainder is worn our the wheels that the drum spin on or the belt is slipping
Feb 01, 2012 | Hotpoint Dryers
Is it dangerous to run a dryer that needs the rear bearing replaced? My dryer just began making the noise tonight. When I started it there was a loud pop then a grinding noise. However, when I removed...
Not dangerous, per se, but if the rear bearing has failed, instead just replacing the bearing sleeve you may have to replace the drum if it wears too much. You have metal and metal contact.
Whilst you have the dryer in bits, replace the front drum slides as well as they will be the next to go.
Dec 06, 2017 | Hotpoint NVLR333EE Dryer
I have a Hotpont washer/dryer model BWD129 It started making a loud noise for a while when spinning now it won't spin at all. Please could you advise if it would be able to be fixed? Many thanks
I would say your basket drive is broke. Only when spinning, if it was this, it makes loud noises the whole time it spins, big thumps. This may be your problem. You would have to have someone look at it or call for an estimate. It would probably need replaced.
Mar 03, 2011 | Hotpoint Washing Machines
Spins but no heat
Update - we solved the same problem by resetting the Stat. Follow the instructions posted by kevinwhiteho, but we found that you had to push on the opposite side of the Stat with your finger whilst pushing the pin onto the trip mechanism.
Dec 27, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint TDC32 Dryer makes a noise like plates sliding
Could be coins in the drum.  Might also be a bad roller bearing.  Hard to tell.
Nov 06, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Dryers Logo
286 people viewed this question
Top Dryers Experts
