Question about Dell 3000cn Color Laser Printer
Paper not feeding
It started suddenly without warning and without a paper jam.
The message is: Paper Jam, Open Reg Cover.
I have opened all doors, cleaned all areas, looked for any sign of paper or a spec of paper. I have found nothing.
The problem appears to be in the bottom roller/feed mechanism.
This printer is a vital part of my business and I cannot be without it!
Please help.
Thank you,
Dave
  • 1 more comment
  • Don Metzler Jul 14, 2008
    I am having the same problem after replacing the black and cyan toner cartridges. The first sheet of paper feeds correctly, but then the feed roller starts griding and I get a message Paper Jam - Open Reg Cover. If I reach in and rotate the roller back after the first sheet of paper feeds, the printer will continue, but start grinding again as each sheet of paper is fed through the rollers.
  • Anonymous Aug 10, 2008
    paper jam open reg door
  • lookcrabs Dec 05, 2008
    We have a 3000cn and it will not load paper as well. The bottom roller doesn't even start to turn. It just says remove reg cover and remove paper. The printers internals are covered in toner so I thought that if I blew it all out with some compressed air and wiped it all down it would be fine.
    The sensor must still be covered in dust or something because i just keep getting the same error.
    I have fixed a lot of hp's before and I thought if you've figured out one laser jet then you can fix any. This is my first dell and I'm stumped. I don't want to waste money on new parts if that's not the problem. Is there a manual or some documents for this printer?
  • 24 Answers
The Dell 3000cn & 3010CN both display this fault.
The root cause of the problem is the Rubber pads of the feed roller in the paper tray become warn and fail to grip the paper the paper feeds a few millimetres and then is let go by the worn roller, the paper path sensors pick this up and then a paper jam is notified.
The only remedy for this problem is to obtain a new feed roller for the paper tray mechanism. Unfortunately dell in the UK do not sell maintenance kits to the public, and therefor ehte only place I found them wa on Ebay in the USA.
The kit in quetsion is the vertical paper feed maintenance kit. it costs around $50 plus shipping.
The only other option is to have a Dell approved service agent replace the rollers for you.
If you hear a grinding or cruching noise when paper is fed, then one of the mini plastic guide rollers had detached itself from its position and wound up in the tape path mechanism (very expensive repair)
Posted on Dec 05, 2008
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Dell 3000cn paper jam open reg cover
Don't take risk about your equipments. consult a enjineer.
Aug 06, 2009 | Dell 3000cn Laser Printer
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam cleared but paper wont feed
try 1. Turn off the printer. 2. Remove any paper trays. Inspect them for wrinkled or damaged paper. 3. Also open the back cover of the printer if this model has one. 4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it. 6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside. 8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. 10. see alternative if the problem is still not solved. alternative : Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam paper jam error message continues even no jam, have to feed by hand sever times before paper will feed into printer.
try this
alternative :
Dec 23, 2008 | Canon Pixma MP450 All-In-One InkJet...
Resetting PaperPort after paper jam
I found the solution to this problem. Whenever the paper jammed in the feed tray, I was pulling the jammed paper out without opening the door of the feed tray. Apparently, PaperPort gets confused and does not know how to proceed. Now when I get a paper jam, I open the door of the feed tray, take out the paper, click on the paper jam error message in PaperPort, reset the paper in the feed tray, and then hit "scan." Works like a charm.
Sep 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Paper Jam error message
try this
alternative :
Apr 02, 2008 | Dell 942 All-In-One InkJet Printer
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
Nov 08, 2007 | Dell 3000cn Color Laser Printer
Dell 3000cn Color Laser Printer Logo
491 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
