Question about Refrigerators
Maytag refrigerator side-by-side model MSD2756GE freezer is working fine, but refrigerator is not cooling. can not hear a fan blowing from freezer to refrigeration side.
  • Anonymous Aug 04, 2008
    My 5-6 year old refrigerator is also having the same problem (model MSD2756GE). The Freezer is still pretty cold, but the refrigerator side is not very cold. I can't hear a fan blowing in my refrigerator either. Any answers to what I should do? I REALLY need help and as soon as possible, so please help me out!
  • Anonymous Dec 29, 2008
    freezere works great, refrigerator stays at 40 degrees
Remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
My Maytag Refrigerator is not Cooling enough. My Freezer works fine and we have unplugged and let everything defrost and plugged back in but still not working properly. Model # is MFD2561HES
Its possible the evaporator fan is bad. Air is drawn from freezer to cool the refrigerator side and ultimately controlled by the fridge side thermostat. Or... Low freon.
Oct 28, 2013 | Maytag Refrigerators
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
my refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Nov 15, 2009 | Maytag MSD2756GES Side by Side...
Maytag MSD2651HEQ frige not cooling; can hear/feel fan blowing
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Maytag MSD2651 HE Side by Side...
Door frame is always hot on freexer side
Is it hot all the way around, or just on the face of the divider between the freezer and fridge? If it's just the divider, then it's probably not a defrost problem. When that divider gets hot, it usually means there is inadequate air flow over the condenser coils outside the unit.
When the compressor is running, check for air blowing under the unit. If no air is moving, then you probably have a failed condenser fan. If the fan is running, then use your vacuum cleaner to clean the coils, and make sure there is space behind the fridge for air to flow.
Jul 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Freezer is fine fresh food side wont cool down
Could be a fan problem; some blow cold air, some just have the coil running throught the back inside. Yo will also get very extended life if you plase a very small fan blowing over the compressor if it does not have one.
Dec 28, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
1,013 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
