Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero 650 -- lights/fan not working
Hi.  My refrigerator and freezer both seem to be cooling properly and making ice, etc., but none of the lights turn on and the LED read-out seems off -- no lights at all.  Any thoughts?  Thanks.
  • 958 Answers
You can check the bulb's resistance if they still have. they could be both busted. if they have, the problem could come from thre door switch if you have mechanical door switches that controls bulbs. on the LED read outs, you could have a loose connection to the main board because if the board is not functioning well, then you should not have a cooling refrigerator.
please rate me, i hope i was able to solve your problem.
Posted on Jul 16, 2008
Freezer not working/but fan is running
The freezer side may be icing up. Soon enough the fridge side may have problems, too. Love those Sub-Zeros, but if the defrost timer fails, it will ice up. Defrost timer is up top. A generic one will do.
Nov 25, 2013 | Sub-Zero 642
The Sub Zero bottom dram freezer has stopped working
HI,
What does you freezer do? Does the lights work and fan work? The fan works with the cold control, if the light switch fails the unit will defrost in about 3 - 4 hours, will remain cold though, just not frozen. I need more information to direct you correctly.
I am here to help
Aug 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
I need to defrost my sub-zero 650. Can you give directions?
This is intended as a guide to defrosting a refrigerator. Side by sides and bottom freezers may be similar but will require some different procedures to remove covers to get at the defrost coils.
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Replace all pieces and wires to their original positions and then restart the refrigerator. It may take a bit for everything to cool back down, especially in warm weather. Now with everything working properly you should be trouble free again.
Good luck
Aug 08, 2010 | Sub-Zero 650 / O Bottom Freezer...
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the...
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Apr 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Refridgerator does not get cool enough
Buttom freezer Sub Zero. Replacing evaporator for fresh food section.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550
You probably have a freon leak in the evaporator coil.
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
507 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
