Question about Car Audio & Video
Car stereo model Nikkai A39FQ. Memory does not work when ignition is switched off, so everything has to be reset. Any advice?
  • agbayle Sep 23, 2008
    i had the same issue, but now the connector is broken and i need to get a replacement, and the pin out diagram any ideas?
If you remove your head unit, you will need to switch the red and yellow wires around! different cars have different modules. yellow will then be constant 12v source! let me know how u get on, i have the same unit!
Posted on Aug 20, 2008
  • David Still
    David Still Mar 30, 2014
    I had this problem with my Nikkai A87FN. I swapped the wires (cut and switched them through a block connector) problem solved. Thanks for the tip!
Why d0 i have to reset my stereo when i turn off my ignition
You dont have power an memory hooked to a contant 12v source so when u turn it off it resets everything
Apr 13, 2014 | Pyle PLBT72G - Single-DIN In-Dash DVD...
Do i need extra wirering to fit a nikkai bluetooth car stereo to a renualt lagouna r reg
The blue tooth aspect is built into the unit. No extra wiring is needed for that. If the cassette you are replacing had digital display and was stereo, you should not need to run any new wires. Nikkai might even have an adapter plug/harness to speed installation as well.
Jun 28, 2012 | Cars & Trucks
My JVC car stereo will reset to factory settings after 5 minutes of the ignition being turned off. what can i do to fix this problem?
The power connection to the car stereo has two positive connections out of which one is connected directly to the main power -CONTINUOUS always ON , and the other is connected through the switch.
In your case I think both the lines are connected directly to the switched output through the main switch.
These are normally Orange and red and you can confirm by connecting orange to switch and red to power or vice versa., (checking by setting memory and switching off to see if it resets to reverse)
Your problem will be solved . Please comment if helpful
Aug 31, 2010 | JVC AM FM CD DET FACE CAR STEREO
I recently bought a JVC KD-R311 car stereo, its a great stereo but my settings dont save, for instance i set the perfect sound adjusting bass/treb/mid/loudness and whenever i turn my car back on after...
You need to have the yellow wire from the stereo connected to constant battery/12 volts. That wire supplies power for the memory, if it is connected to ignition power, when you turn off the car, the power for the memory is off also.
May 13, 2010 | JVC AM FM CD DET FACE CAR STEREO
Need manual for nikkai a38fq bluetooth enabled cd/mp3 car stereo
hi there how do i connect my phone to the bluetooth on the nikkai a38fq thanks nick
Oct 30, 2009 | Car Audio & Video
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Automatically goes to the demo mode on start-up
to turn off demo mode put radio into stand by were it is running demo mode and hold number 6 till it switches off. As for the key problem its the key that is making the key live connection on your model of car so this can not be changed. sorry
Apr 29, 2009 | Car Audio & Video
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
Car CD stereo
Either you blew the memory fuse or didn't connect the radio to the proper wire. Check fuses inside and under the hood.
The memory wire to the radio needs 12v all the time. If it's not connected or no power at the lead the radio will reset every time you turn off the car.
Jul 08, 2008 | Car Audio & Video
Everytime i turn my car off and take the key out of the ignition all my stereo presets reset. all connections made are correct, however there is one wire which is left over. it is orange with white stripes...
Most stereos have two power connections. One is "constant" (aka always connected to +12V) and the other is switched on/off by the ignition. They may go be various names. The idea is that the constant +12V keeps the stereo from losing all of the settings while the switched power turns the stereo off when the key is not on "start" or "accessory". It sounds like the both connections may be made to the switched power on your car, causing it to go completely powerless when your car is off.
Are the presets reset after you turn the car off or only after you turn your car back on? If they only reset after turning the car back on, it's possible the battery and/or electrical system is having trouble keeping the system voltage up while the starter is trying to turn the engine.
The illumination signal is usually used to let the stereo know when you've turned your headlights on, so it can dim the display automatically. Should be completely separate from your issue.
Apr 02, 2008 | Car Audio & Video
Car Audio & Video Logo
361 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
