Question about Saeco Vienna De Luxe Espresso Machine
Saeco Magic Superautomatica de luxe problem
When trying to dispense hot water, the pump stopped dispensing, emitting only a soft hum, and the water indicator light started blinking. The manual says that the pump must be drained. I've spoken to two different customer support people at Saeco who have told me that the pump is air locked and needs to be primed. I'm skeptical since I know what these pumps sound like when they're sucking air and that's not the sound that I hear. Furthermore, when I try using the priming pump, I'm unable to force any water into the system. It thus seems to me that I have a hydraulic lock and that the pump indeed does need to be drained. Do you know how I might bleed the pump? I think one possibility is that the wand valve isn't opening and that that's why the pump is locked. To test this, I'd like to just reset or bypass the "pump not functioning" indicator to try brewing. What might you suggest?
  • 515 Answers
I think your "water turbin" also called flow meter is gone and have to be replaced.
To check this you can do the following:
Open the steam knob and try to make a cup of water, if you only get a half cup of water then the flow meter has to be replaced.
If you not get any water then you have air in the system, to fix this you have to get a little bellowspump or similar.
That you have to do is:
  1. Fill up the pump with water
  2. open the steam knob, when the pump starts remove the water tank and set the pump in the water inlet
  3. press in water with force, that can happen you must do this more than one time.
Try to do this and hope you get your coffee:-)
Posted on Jul 13, 2008
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe resets itself before completing brew cycle
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that doesn't fix it, then you might need a new flow meter.
Jun 12, 2009 | Saeco Magic De Luxe Espresso Machine
Red water light is flashing
Check your water flowmeter. Check the turbine is not scaled or clogged.
Apr 24, 2009 | Saeco Magic De Luxe Espresso Machine
I read through many old posts and found the answer I was looking for. I turned the hot water nozzle on for 45 seconds and the problem went away.
Apr 10, 2009 | Saeco Magic De Luxe Espresso Machine
Only half of a cup of coffee dispensed from Saeco Vienna
the trouble is the pipe that goes to the water tank follow it its hook to a white plastic sensor go in that piece and come out that the level sensor that broken that the first thing and most likely broken if not the circuit board
Apr 04, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Magic Deluxe - Coffee Cold,Lights not working
The thermoblock (boiler) element is burnt out and must be replaced.
Feb 10, 2009 | Saeco Magic De Luxe Espresso Machine
How do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Magic De Luxe Espresso Machine
Magic De Luxe Frother won't work!
means you do have the hot water button pushed and not just the steam function.
Follow this SAECO
Jun 03, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic
I believe the model you have has no user-selectable temperature settings. The manual for the Magic line suggests preheating the cups as the fix. You can use the electronic cup warner OR run your tap/faucet water as hot as possible, fill the cup you're going to be dispensing espresso into with hot water while your Saeco warms up...right before you hit the button to dispense espresso, empty the hot water, dry the preheated cup and you're set! It only takes a few seconds. This way, you waste none of your coffee's thermal emergy on cup heating and your coffee will stay hot longer. Hope this helps!
Jan 02, 2008 | Saeco Magic De Luxe Espresso Machine
Part 2 -Flashing water light - will drain water but will not make coffee
Blinking light often means pump is not delivering water. Possible blockage from corrosion. Can also mean a valve blocked.
Do you hear the pump run?
Dec 11, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
408 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Shehu Pro
Shehu Pro
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
