Question about Dualit 20247 2-Slice Toaster
Faulty timer I used the toaster and the timer was fine, but when I went to use it again ten minutes later, the timer was stopping and starting.  This isn't a problem that happened gradually... one minute it was working and the next minute it wasn't.  I had to keep checking the toast to see how it was doing so it wouldn't burn and eventually advanced the timer manually to the OFF position, where it still continued to emit short bursts of noise until it finally stopped.
  • tpmccann Nov 16, 2008
    Same details. Timer stopped working 30 days outside guarantee period
  • alexvildard Mar 26, 2009
    Hi everyone.
    I have a dualit toaster 2 slice. i took it apart years ago, and now igot a switch for it. but for some reason i reckon the switch isdifferent from the last one.
    it has neutral next to a number 1
    live next to a number 4
    and a connection at number 2, and one at number 5
    I vae a two way switch with 3 connectons,with no indication of what goes where?
    the plug wire has the usual brown blue and green, green already earthed to case.
    and from the elements you have, 2 reds and 1 blue. there is also aconnection wire on its own, i beleive one of the ends would connect tothe switch.
    Can anyone help please
Dualit service center:
41 Woodbine St
Bergenfield NJ 07621
ph 201-439-1700
Posted on Sep 03, 2008
Can your washer front load run off a portable generator power
You probably fried the control board. The older machines would work fine on a generator but the newer ones are sensitive to power fluctuations.
Nov 01, 2012 | Bosch Nexxt 300 Series WFMC2201UC
Kubota will not start again
The pushrod may not been in lifter.
Sep 17, 2012 | Kubota Garden
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
The timer on my Dualit Marmite toaster has stopped working properly. It is a clockwork timer and from time to time, just stops going round, which is dangerous. How do I repair it?
As with all clockwork mechanisms, they all have springs and gears and side plates, they are not too hard to fix, as long as you don't release the spring, then it's a mission to get it back, into the container, (it's a bit like toothpaste comes out easy very hard to put it back into the tube)..So careful removal, and maybe just cleaning out may help, toasters are fairly simple devices, as you will see if you disassemble, remove the wires from the Timer, write down draw a diagram of where they went, now, have a good look, and maybe even do a rough drawing of how it all looks, no, give it a good clean, and grease up, and maybe you can save it. if it has open set contacts, then clean them with fine sandpaper, tighten everything up, and test it. When all is well, put back into the toaster and wire back up, check over again, and power up, stand back, and admire your work, well hopefully. Be very careful of the Elements they are very fragile...
May 06, 2010 | Dualit Vario 2 Slices Toaster
Vehcile will start then will not start again maybe ten min later. GAS GUAGE DOES NOT WORK LIGHT ALAWYS ON BUT I DO HAVE GAS.engine light on
it sounds as if your fuel pump is getting weak checkout the fuel pump relay first you may even want to give these guys a call they only sells GM-parts its Schram auto & truck parts 1-800-292-1092 and they website is wish you the best of luck Michigan Man.
Dec 28, 2009 | 2006 Chevrolet Trailblazer
Car died then restarted three times
Run a scan tool to determine problem, if nothing found take the car to the nearest acura service center to check for any recall onthe car.
Jul 09, 2009 | 1997 Acura TL Series
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Go to for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dualit 20247 2-Slice Toaster Logo
318 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
