Question about EliteGroup ECS PT880Pro-A (1.0A) Via Socket 775 ATX Motherboard / Audio / AGP 8x/4x / PCI Express Lite / 10/100...
Windows can't detect any hard drive
Hi there.....i have a problem with my computer.when i want to install windows, the windows can not detect any hard drive on my computer.the main board is ecs elitegroup PT880PRO-A,hard drive seagate ST380211AS, processor INTEL PENTIUM 4 3.0 GHz.
bios detect hard drive 4M-ST380211AS (it should be 3M-ST380211AS).
when i clear the bios with remove the battery,it doesn't effect to BIOS.
please help me......
How to make windows can detect the hard drive.
thanks a lot
Windows can't detect any hard drive in PT880PRO-A ELITEGROUP OPEN BIOS
OPEN "Features setup"
Change "OnBoard SATA-IDE" Than "RAID" TO "IDE"
Posted on Dec 17, 2008
    Scholar:
  • 58 Answers
Hello.
Have you check if every thing is ok in the setup ?
If you have the documentation of your Hard drive, set the HDD
manually( cilinders, heads, etc), i don't know the difference between 4M and 3M models, but may be significant.
The battery wont have any effect in the BIOS, you should thanks god for that, because if you could erase what is in the BIOS you could say good bye to your PC.
In order to recognize many new devices the BIOS manufacturer make software updates you can download ( if available)from they website an install it ( i don't recommend you to do that unless you have no other option).
The battery is only for the CMOS, a memory that keeps your setup configuration when you turn off your PC.
- Most Probable cause of that problem and possible solution:
You hard drive must be partitioned and properly formated.
You will have to start you computer using a 3 1/2 floppy disk or bootable CD with MS-DOS.
Note: go to SETUP and set the right drive to boot from first( A: in case of floppy, CD in case of CD), save and exit
Make sure the disk have some commands you will need, FORMAT among them.
I suggest you look for totorials about partitioning a hard drive.
Is no big deal but you have to know what you are doing.
Create a partition using FDISK command and activate it
then format the drive.
Now it is ready to be recognized for Windows.
In the process of windows installation( only XP), right before it start it will ask if you wish to format de Drive, answer yes( the fast one) and choose NTFS( a more efficient Partition for windows XP.
I hope this help you.
Good luck
Posted on Jul 13, 2008
  • Enrique Barrios Jul 13, 2008
    Hi.
    Forgive me, i forgot something important, on the internet you can find an utility made by the hard drive manufacturer for MS-DOS you can use to make the partition, its the easiest way.
    if you can't find that specific Program,There are other softwares,
    that can help you.
    Regards
    One more thing, make sure the jumpers configuration of your hard drive is set to MASTER, before doing anything.
    President:
  • 1,314 Answers
Turn off ahci in bios.
  • Kevin Shafer
    Kevin Shafer Jul 16, 2008
    Rate it badly if you want, fact is it's a new computer and windows xp won't recognize the hard drive unless you either turn off the ahci in the bios (or change it to IDE mode) or by pressing F6 during setup at the prompt and loading in SATA drivers manually.
Hard disk drive not detected during installing windows server 2003
It depends on what type of drive you are using. Plus, you may have to specify the array controller drivers if your are using the SAS (Serial Attached SCSI) drives.
May 22, 2013 | Dell POWEREDGE R610 (4640223) Server
Hard drive cannot detect
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 03, 2013 | Computers & Internet
Detect
May 01, 2013 | Transcend USA 120GB Storejet 2.5" SATA -...
I can't install windows xp in samsung n110
Aug 11, 2012 | Samsung N110-12P Notebook
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
My External Hard Drive isn't working anymore, to say the just of it. It's on, lights on(not flashing, it flashes when it's being written to or accessed), usually has a regular clicking noise from it...
When a hard drive makes a clicking noise, this indicates the hard drive has failed and if the BIOS and the Computer Management does not detect it, then this confirm a hard disk failure.
To get the computer operating again, replace the hard disk, then install Windows on the hard disk using the Windows installation CD and the Windows product installation code that is on the label on the computer then install the device drivers and your programs.
Oct 21, 2010 | Samsung Computers & Internet
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
Hi, i am unable to install windows XP in pavilion dv6500 laptop. XP set up is not detecting the hard disk at all can you help me ?
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
Jan 31, 2009 | HP Pavilion DV6500T Notebook
Transcend 250 GB Hard Drive not recognized by Windows XP SP2
u may got installation cd for storage device.if not download software from www.transcend.uk  ......... otherwise try for this..
goto control panel...
then goto add hardware...
overthere check out for connectivity
Jan 28, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computers & Internet Logo
621 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
