I drive a honda jazz 1.4 2002 model with a tape player. I would like to know were I could find a cd player console that could fit the cd players are oftenly used in the market.
I do not want the solution of a cd changer because it takes too much space in the trunk.
Plus, the cd player console of the jazz 2006 model could fit but with a substantial cost.
The solution of an i pod could be an option If not anything else.
please advise. [email protected]
SOURCE: 2005 Honda Odyssey - Replacing CD Player
I've been looking for instructions to remove the stereo in my 2005 Odyssey as well. I found these instructions that should help: http://www.collegehillshonda.com/instructions/gen3_odyssey/musiclink.pdf It is actually for adding something else to the stereo, but there are instructions for removing the stereo there. You can easily find a kit that allows you to mount a standard car stereo in the space. You might also check out http://www.crutchfield.com Any stereo bought there comes with the necessary mounting kit and harness for your vehicle, as well as vehicle-specific installation instructions.
SOURCE: Code for CD Player of Honda Odyssey 2000
The code is either on the inside of your glove box or on a card in your owners manual. if not there then you need to phone the honda dealer that the vehicle was purchased new and ask them to do a search for you on E biz
SOURCE: removal of door pad on honda jazz 2006 year model
door pad removal look for little pop outs take the pop outs off and thenremove screw then remove the mirror cover then pull on the bottom of door then pull on the side and then pull off trim up and out then you will see a vapor barrier remove it then you see the inside handlejust acouple of srews /please rate my response thank you very much
SOURCE: Jammed cd player - 2002 Honda Accord
I have a 2002 honda accord with the 6 disc cd changer. I beleve the cd changer has jamed and have lost power to the CD player. When I press the CD button it wont recognise the player. Any suggestions
SOURCE: 2004 honda accord CD player not working
i say trash the old one and buy an aftermarket because if your screen went out like mine and then the cd player doesnt work then just go ahead and just get rid of it.
