Question about Mitsubishi VS-50605 50" Rear Projection Television
Brightness on VS-50605
Thanks for the blue screen help. I am checking into a new screen. The second problem is that the picture is very dark and blurry. But, when you change the channel, for a split second it is very bright and looks good (still blurry, but much brighter), then it quickly switches back to very dark. I tried all types of inputs and never get a bright screen. I hate to buy a screen and still not be able to watch the thing because it never gets bright enough to view. And, is this a TV I should put some money into, or should I give up and buy something new?
  • jeepmanmatt Jul 14, 2008
    Thank you very much for the help.
  • Mitsubishi Master
  • 8,617 Answers
The darkness shouldnt be that exspensive some trouble shooting and a few dollars should straighten that out. The screen however will cost a couple of hundred dollars, although that would still be cheap for a big screen, and that model does play exceptionall well when operating properly.
Posted on Jul 12, 2008
The screen is really dark
Locate the Fn (Function) key on your keyboard. It may be on the bottom left side with dark blue letters. Locate the two "brightness" keys near the top of the keyboard. These will be in the "F" keys, possibly if F6 and F7. They should have little sun pictures or something similar to indicate brightness. Hold down the Fn key while pressing F7, or whichever "F" key your laptop uses to increase brightness. Tap F7 repeatedly until you reach the desired brightness. Fn must be held down as you continue to tap. Hope this helps.
Dec 07, 2012 | Intel EasyNote E4 715 Notebook
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi WD-62527. Dark picture.
That unit is a two mirror set. Meaning the light engine lens shines down onto a small mirror and that is reflected onto a large mirror and then onto the screen. Gravity being what it is dust and other contaminants cover the lower mirror. Moving the set would only aggrevate dust settling on it. To fix the problem the screen must be removed and the mirror cleaned. You won't believe the difference. It will be like watching a new tv.
May 28, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Very dark wd 62725
try pulling the front panel off and cleaning the bulbs inside and the mirrors and all screen protecters and magnifier, just becarefull not too scratch them
May 10, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi 50605
Got the info. Working on my second 16 hour day. I'll update this tonite. Sorry about the delay.
Oct 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Blue Screen
no those tvs came with a black otuer screen that have rough ridges . If your screen is blue, someone may have replaced it with a dark colored plastic. You can get replacement screens at the following link, They are exspensive though.
Jul 12, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Screen goes dark
I thught I answered this one but if you disconnet the sensor it should brighten up the picture If it dosent then its part of the brightness curcuit and must be replace. As I remeber thewre are severall models that you could simply disconnect. Or there should be an auto brightness feature in the main menu picture ajustment to simply disable or shut it off. Good luck
Apr 22, 2006 | Mitsubishi The Big Easy TV
Mitsubishi VS-50605 50" Rear Projection Television Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
